Thank you for these hints. I have tried adding value_shape() but it yielded an error with the variational form.
Therefore I produced a MWE as suggested and uploaded it here (including the mesh): Fenics/anisotropy.zip at 0f7845fdf94b00e990af70632c401925d438243f · bragostin/Fenics · GitHub
The python code itself is:
from msh2xdmf import import_mesh, msh2xdmf
from ufl import Min
# LOAD MESH
mesh, boundaries, subdomains, association_table = import_mesh(prefix='anisotropy', dim=3, subdomains=True)
# Boundary conditions
HTC = 10000. # (W/m2 K)
Tref = 60. # (°C)
qc = 100. * 1e4 # (W/m2)
# Define subdomain markers
markers = MeshFunction('size_t', mesh, 3, mesh.domains())
print("association_table = ", association_table)
# Define thermal conductivity
class Thermal_Conductivity(UserExpression):
# Returns error : ufl.log.UFLException: Can only integrate scalar expressions. The integrand is a tensor expression with value shape (3, 3) and free indices with labels ().
#def value_shape(self):
# return (3,3)
super().__init__(**kwargs) # This part is new!
self.markers = markers
if self.markers[cell.index] == association_table['base']:
#values[0] = 100. # isotropic --> works
values = as_tensor([[100., 0, 0],[0, 100., 0],[0, 0, 100.]])
#values[0] = 10. # isotropic --> works
k = Thermal_Conductivity(subdomains, degree=1)
# Build function space
T = TrialFunction(V)
s = TestFunction(V)
ds_bc = ds(subdomain_data=boundaries)
bcs = []
# DEFINE VARIATIONAL FORM
F = (
- k*inner(grad(T), grad(s))*dx
- HTC*(T - Tref)*s*ds_bc(association_table["htc"])
+ qc*s*ds_bc(association_table["top1"])
a, L = lhs(F), rhs(F)
# Create VTK files for visualization output
vtkfile_T = File('Temperature.pvd')
T = Function(V, name='Temperature')
#solve(a == L, T, bcs)
solve(a == L, T, bcs, solver_parameters={'linear_solver':'mumps'})
# Save solution to file (VTK)
vtkfile_T << T
# Isotropic max temperature = 310 --> OK
# Anisotropic max temperature = 12000 --> not OK
