I learned to map a function defined on a submesh by MeshView() to another function defined on the parentmesh from MeshView submesh vertex map to parent mesh, however, assign the vertex value accoding to the index mapping is apprently not annotated. Below is MWE that I tried. I would like to know how could I make this kind of mapping work for dolfin-adjoint. Many thanks!
from dolfin_adjoint import *
parentmesh = UnitSquareMesh(10, 10)
class Block(SubDomain):
return between(x[0],(0.4,0.6))
subdomains = MeshFunction("size_t", parentmesh, parentmesh.topology().dim())
subdomains.set_all(0)
Block().mark(subdomains,1)
submesh = Mesh(MeshView.create(subdomains, 1))
A = FunctionSpace(parentmesh, "DG", 0)
A_sub = FunctionSpace(submesh, "DG", 0)
x = interpolate(Constant(0.0), A)
x_sub = interpolate(Constant(1.0), A_sub)
sub_to_parent = submesh.topology().mapping()[parentmesh.id()].cell_map()
values = x.vector().get_local()
#print(len(sub_to_parent))
for cell in cells(submesh):
values[sub_to_parent[cell.index()]] = x_sub.vector()[cell.index()]
x.vector().set_local(values)
plot(x)
m = Control(x_sub)
dx = Measure('dx', domain = parentmesh, subdomain_data = subdomains)
J = assemble(x*dx(1))
grad_vec = compute_gradient(J, m)
print(grad_vec.vector().get_local())
