Formulation with functions from parent mesh and submesh
Hi all,
I have a function defined on a submesh and a function defined on the parent mesh.
I would like to use both in a formulation (consider the following MWE).
import dolfinx.fem.petsc
import basix
def half(x):
    return x[1] <= 0.5 + 1e-14
mesh = dolfinx.mesh.create_unit_square(
    MPI.COMM_WORLD, 10, 10, dolfinx.mesh.CellType.triangle
# Split domain in half
gdim = mesh.geometry.dim
tdim = mesh.topology.dim
bottom_cells = dolfinx.mesh.locate_entities(mesh, tdim, half)
num_cells_local = (
    mesh.topology.index_map(tdim).size_local + mesh.topology.index_map(tdim).num_ghosts
cells = np.full(num_cells_local, 4, dtype=np.int32)
cells[bottom_cells] = 3
ct = dolfinx.mesh.meshtags(
    mesh, tdim, np.arange(num_cells_local, dtype=np.int32), cells
submesh_b, submesh_b_to_mesh, b_v_map = dolfinx.mesh.create_submesh(
    mesh, tdim, ct.find(3)
)[0:3]
submesh_t, submesh_t_to_mesh, t_v_map = dolfinx.mesh.create_submesh(
    mesh, tdim, ct.find(4)
)[0:3]
def create_function(mesh):
    degree = 1
    element_CG = basix.ufl.element(
        basix.ElementFamily.P,
        mesh.basix_cell(),
        degree,
        basix.LagrangeVariant.equispaced,
    V = dolfinx.fem.functionspace(mesh, element_CG)
    u = dolfinx.fem.Function(V)
    return u
u_b = create_function(submesh_b)
u_t = create_function(submesh_t)
u_b.interpolate(lambda x: x[1])
u_t.interpolate(lambda x: 1 - x[1])
# Create a function on the full mesh
T = create_function(mesh)
T.interpolate(lambda x: 10 + x[0])
# compute something with a mix of both
ds_b = ufl.Measure("ds", domain=submesh_b)
dx_b = ufl.Measure("dx", domain=submesh_b)
dx = ufl.Measure("dx", domain=mesh)
n_b = ufl.FacetNormal(submesh_b)
form = dolfinx.fem.form(T*ufl.dot(ufl.grad(u_b), n_b) * ds_b)
print(dolfinx.fem.assemble_scalar(form))
This produces:
  File "/workspaces/FESTIM/mwe_post_processing.py", line 89, in <module>
  File "/usr/local/dolfinx-real/lib/python3.12/dist-packages/dolfinx/fem/assemble.py", line 140, in assemble_scalar
    coeffs = coeffs or _pack_coefficients(M._cpp_object)
IndexError: map::at
I found that creating another function defined on the submesh and interpolating works:
T_b = dolfinx.fem.Function(u_b.function_space)
T_b.interpolate(T)
form = dolfinx.fem.form(T_b*ufl.dot(ufl.grad(u_b), n_b) * ds_b)
I was wondering if this was the way to go or if there was another (better?) method.
Cheers!
You need to supply entity maps from the integration domain, here
The domains submesh_b. Therefore you need to send in the sub_to_parent_entity map, ie.
import basix
def half(x):
num_cells_local = (
)[0:3]
    degree = 1
        mesh.basix_cell(),
        degree,
    return u
T.name = "T"
u_b.name = "u_b"
    T * ufl.dot(ufl.grad(u_b), n_b) * ds_b,
    entity_maps={mesh: submesh_b_to_mesh},
Which version of dolfinx is required to execute this code? I just tried on 0.8.0 (conda) and jpdean’s branch on docker (which is at 0.7.0) but none worked.
The dolfinx nightly docker image works, or the 0.8.0 image, if you change:
to
    entity_maps={mesh._cpp_object: submesh_b_to_mesh},
