for post-processing, I’m repeatedly applying the Laplace operator to a function like
out = Function(V)
lap = div(grad(u))
for i in range(1e4):
# some computations to get u ...
out.vector()[:] = project(lap, V).vector()[:]
Running this for large meshes in parallel is incredbly slow (much slower than the computation of u itself). Is there a smarter way to do this?
Hi, a call to project includes assembly of the mass matrix of the space, the right hand side vector and finally a solve of the resulting linear system. For repeated projections this is inefficient. Note that the matrix stays needs to be assembled only once. Similarly, you can reuse the solver.
mesh = UnitSquareMesh(128, 128)
V = FunctionSpace(mesh, 'CG', 2)
f = Function(V)
# Projection lhs and rhs
lhs = inner(u, v)*dx
rhs = inner(div(grad(f)), v)*dx
A, b = map(assemble, (lhs, rhs))
solver = PETScKrylovSolver('cg', 'amg')
# Build solver once
solver.set_operator(as_backend_type(A))
solver.parameters['relative_tolerance'] = 1E-12
solver.parameters['monitor_convergence'] = True
laplace = Function(V)
x = laplace.vector()
for i in range(10):
# Update
f.assign(interpolate(Constant(i+1), V))
# Only b need to be recomputed
assemble(rhs, tensor=b)
niters = solver.solve(x, b)
print(i, x.norm('l2'), 'with', niters)
