Solve A.T x = f
I am trying to implement the adjoint state method. To do this I have to solve
A^T \lambda = f
where \lambda, and f are vectors and A^T is the transpose of the matrix A, which comes from
dolfin.assemble(a).
Originally I did this by using
import dolfin
dolfin.assemble(dolfin.adjoint(a))
but for the specific bilinear form I have, the assembly takes nearly 20X longer than assembling its adjoint!
I have tried assembling a simple bilinear form a, and its adjoint and the assembly times are basically the same, so I’m super confused why it takes longer for my case.
Does anyone know of a way to do this without assembling the adjoint of the form, or how to speed up assembly of the adjoint of a form? I’m trying to extract a MWE on my case but I’m not sure the exact part of it that’s making assembly of the adjoint slow.
I am using the version of FEniCS installed through Anaconda.
Thanks alot!
Jonathan
Take a look here: https://fenicsproject.org/qa/10386/impossible-operations-on-matrices-objects-a-b-a-t/
Thanks, that helps a lot! I was able to get it working using the transpose through petsc4py, but I still think there an issue with assembling the dolfin.adjoint() applied to a form that somehow makes it slower when the form is complicated enough.
I’ll try to figure out what makes it slow in my case when I get a chance.
Update
I figured out why assembling the adjoint was so slow.
I was using making the adjoint form in a loop. If you premake the adjoint form outside of the loop, then there’s basically no difference in speed.
# This is slow in a loop
dfn.assemble(dfn.adjoint(form))
