Hello, Ihave tried to visualize delta in the code below, could you please try to see it? I am getting an error (output message) in paraview when I open PRO.pvd there and wondering if you will too. Thanks in advance.
Thanks a lot, is it possible to convert this example to 3d like this? I am getting this error when I tried I was able to see 3D axis earlier.I don’t know why it did not work now.
NotImplementedError: It is not currently possible to manually set the aspect on 3D axes
I will not run your code as you have not formated it properly with ```.
The 3D plotting issue is Fixed in dolfin master, and is because matplotlib changed behavior after the 2019.1.0 release. You can find a working image for plotting with matplotlib on quay.io.
However, in 3D, save it to file and visualize it in Paraview.
Ok thank you. I am running the code you provided in jupyter notebook and I can see this plot
However, pvd file 1 KB and I am getting error still. What should I do?
Which paraview version are you using? What is the error message? 3D plotting in a notebook is something you should avoid or use dedicated software such as vtkplotter for.
