Imposing a given force on a part of the domain boundary
Good morning,
I try to adapt the example "Setting multiple Dirichlet, Neumann and Robin condition of the Fenicsx documentation to my problem.
I want to apply a uniform force ((1, 0) on the boundary x[0] = 0 of a rectangle domain (L x W).
To do so I mark the factes as explained in “robin_neumann_dirichlet.html”.
Then I define the linear part of the variationnal formulation using ufl.ds(4)
Unfortunately I obtained a null displacement solution, which means the prescribed force are not taken into account.
If I use ufl.ds, (ie integration over all the boundary) the solution is no more zero.
I tried to integrate over ufl.ds(1), ufl.ds(2), … but I always obtained a naught displacement solution.
I tied to find a solution on the forum but I did succeed.
I apologize if this topics as already been addressed.
Here is my script.
Thank you in advance for any answer
Regards
Xavier
External libraries
import os
from dolfinx import mesh
from dolfinx import fem
from dolfinx import io
Problem data
L = 1.
W = 0.2
mu = 1.
lmbda = 1.25
p0 = 10.
pL = 0.
nx = 20
ny = 6
deg_u = 1
Def strain tensor
return 0.5*(ufl.nabla_grad(u) + ufl.nabla_grad(u).T)
Def stress tensor
def sigma(u):
return lmbda * ufl.nabla_div(u) * ufl.Identity(2) + 2. * mu * epsilon(u)
Generating the mesh
Omega = mesh.create_rectangle(MPI.COMM_WORLD,
[np.array([0., 0.]), np.array([L, W])],
[nx, ny], cell_type=mesh.CellType.triangle)
Identifying the facets to apply boundary conditions
boundaries = [(1, lambda x : np.isclose(x[1], 0.)),
(2, lambda x : np.isclose(x[0], L )),
(3, lambda x : np.isclose(x[1], W )),
(4, lambda x : np.isclose(x[0], 0.))]
facet_indices, facet_markers = ,
fdim = Omega.topology.dim - 1
facets = mesh.locate_entities(Omega, fdim, locator)
facet_indices.append(facets)
facet_tag = mesh.meshtags(Omega, fdim, facet_indices[sorted_facets],
facet_markers[sorted_facets])
ds = ufl.Measure(“ds”, domain=Omega, subdomain_data=facet_tag)
Function spaces and functions
V = fem.VectorFunctionSpace(Omega, (“CG”, deg_u))
u = ufl.TrialFunction(V)
Problem definition
Define boundary conditions
ud = np.array([0., 0.], dtype = ScalarType)
facets = facet_tag.find(1)
dofs = fem.locate_dofs_topological(V, fdim, facets)
bc1 = fem.dirichletbc(ud, dofs, V)
facets = facet_tag.find(3)
bc3 = fem.dirichletbc(ud, dofs, V)
Define variational problem
f = fem.Constant(Omega, ScalarType((1., 0.)))
L = ufl.dot(f, v) * ufl.ds(4)
Computing the solution
problem = fem.petsc.LinearProblem(a, L, bcs=[bc1, bc3],
petsc_options={“ksp_type”: “preonly”, “pc_type”: “lu”})
uh = problem.solve()
uh.name = “Displacement”
Computing the norm of the displacement
norm_uh = np.sqrt(Omega.comm.allreduce(fem.assemble_scalar(fem.form(ufl.inner(uh, uh) * ufl.dx)), op=MPI.SUM))
print("norm uh = "+str(norm_uh))
Writing XDMFFile for Paraview
with io.XDMFFile(Omega.comm, “marking_boundary.xdmf”, “w”) as xdmf:
xdmf.write_mesh(Omega)
xdmf.write_function(uh)
It seems I find the solution.
I just replace ufl.ds(4) by ds(4) and it works.
I just have to use the measure I defined with the line
I close the topics
