Applying linear transformation on mesh
Hi!
I’m working with a 3D model from an XDMF file on dolfinx and would like to apply the transformation r_0(x-x_0) to the mesh.
with XDMFFile(MPI.COMM_WORLD, "model.xdmf", "r") as xdmf:
    ct = xdmf.read_meshtags(mesh, name="Grid")
That is, from mesh, I would like to obtain a new_mesh such that new_mesh=r_0*(mesh-x_0).
Thanks in advance.
You can directly access the geometrical coordinates of the mesh with mesh.geometry.x, which returns you a numpy array. You can modify this array with any transformation or reassignment, i.e. consider:
x_copy = mesh.geometry.x
mesh.geometry.x[:, 0] = np.cos(x_copy[:,0])
with dolfinx.io.XDMFFile(mesh.comm, "u.xdmf", "w") as xdmf:
    xdmf.write_mesh(mesh)
Thank you very much!
