XDMFFile in DolfinX
I’m trying to migrate provided code from dolfin to dolfinx.
When exporting group meshes from FreeCAD I save them as .xdmf files
Using dolfin I can read .xdmf files using
meshfile = meshpath+"mesh.xdmf"
mesh = Mesh()
with XDMFFile(meshfile) as infile:
    infile.read(mesh)
In this tutorial there is this snippet
with XDMFFile(MPI.COMM_WORLD, "mesh.xdmf", "r") as xdmf:
    ct = xdmf.read_meshtags(mesh, name="Grid")
mesh.topology.create_connectivity(mesh.topology.dim, mesh.topology.dim-1)
with XDMFFile(MPI.COMM_WORLD, "mt.xdmf", "r") as xdmf:
    ft = xdmf.read_meshtags(mesh, name="Grid")
But when I try to run this I get the traceback that there is a missing .h5 file.
    with XDMFFile(MPI.COMM_WORLD, meshfile, "r") as xdmf:
RuntimeError: Unable to open HDF5 file. File mesh.h5 does not exist.
Default encoding is HDF5, should I be changing that to ASCII or am I on the wrong track?
Regards
Ólafur Marteinsson
Could you share the content of your xdmf-file? Does it contain all the arrays in plain-text? If so you should read it with ascii encoding
Thank you for looking into my issue.
.xdmf file can be found here
Here are the first few lines of the .xdmf file
<?xml version="1.0"?>
<!DOCTYPE Xdmf SYSTEM "Xdmf.dtd" []>
<Xdmf Version="3.0"><Domain><Grid Name="base_mesh" GridType="Uniform"><Topology TopologyType="Tetrahedron" NumberOfElements="6071" NodesPerElement="4"><DataItem NumberType="UInt" Dimensions="6071 4" Format="XML">667 1145 1013 1183
161 201 741 1090
995 590 1200 1379
995 1200 590 1425
1017 330 1190 1353
946 1020 1289 1347
MWE since I didn’t include it in my original post.
from dolfinx import geometry
from dolfinx.io import gmshio, XDMFFile
from dolfinx.fem import FunctionSpace, Function, Constant
from ufl import dx, grad, inner, ds, Measure
with XDMFFile(MPI.COMM_WORLD, "mesh.xdmf", "r") as xdmf:```
I would try to use the ascii encoding mode.
I have to ask since I can not figure it out by myself.
How do I change the encoding mode?
dolfinx.cpp.io.XDMFFile(comm: MPICommWrapper, filename: os.PathLike, file_mode: str, encoding: dolfinx.cpp.io.XDMFFile.Encoding = <Encoding.HDF5: 0>)
For instance with
with dolfinx.io.XDMFFile(mesh.comm, "mesh.xdmf", "r", encoding=dolfinx.io.XDMFFile.Encoding.ASCII) as infile:
    mesh = infile.read_mesh(name="base_mesh")
I have the same problem. Here is my xdmf file - Download mesh.xdmf | LimeWire
My xmdf file code is given below. The above solution does not work
<Xdmf Version="3.0"><Domain><Grid Name="Grid"><Geometry GeometryType="XY"><DataItem DataType="Float" Dimensions="15540 2" Format="HDF" Precision="8">mesh.h5:/data0</DataItem></Geometry><Topology TopologyType="Triangle" NumberOfElements="30546" NodesPerElement="3"><DataItem DataType="Int" Dimensions="30546 3" Format="HDF" Precision="8">mesh.h5:/data1</DataItem></Topology></Grid></Domain></Xdmf>
The XDMFFile is not sufficient without the hdf5 file. How did you generate this xdmf file ?
Oh, thanks. I discovered the h5 file is in the same folder as the generated xdmf.
