Applying non-zero Dirichlet boundary conditions via Function using Mixed Function Spaces
I am struggeling with applying non-zero Dirichlet boundary conditions in a mixed function space.
Zero Dirichlet boundary conditions work just fine via:
dof_boundaries = {}
boundary_condition = [(lambda x: np.isclose(x[0], 0), 'bdry')]
for marker, dof_name in boundary_condition:
    facets_bdry = mesh.locate_entities_boundary(msh, dim=fdim, marker=marker)
    dof_boundaries[dof_name] = locate_dofs_topological(V=mix_elem_space.sub(0), entity_dim=fdim, entities=facets_bdry)
dirichletbc(value=0.0, dofs=dof_boundaries['bdry'], V=mix_elem_space.sub(0))
However, when I try to impose a non-zero boundary condition via
v_space, _ = mix_elem_space.sub(0).collapse()
bc_v_l_fun = Function(v_space)
bc_v_l_fun.interpolate(v_exact_fun(t))
dirichletbc(value=bc_v_l_fun, dofs=dof_boundaries['bdry'])
the nonlinear solver diverges in the first step. When having only one function space there are no problems with non-zero Dirichlet boundary conditions. Maybe I a missing something with respect to the collapsed function space?
Thank you for your help.
Here is a MWE that reproduces the issue:
# In this minimal working example, we try to solve the PDE system
# \partial_t u -\nabla**2 u + v - f(x,t) = 0
# \partial_t v -\nabla**2 v + u - g(x,t) = 0
# with Dirichlet boundary conditions.
# Method of manufactured solutions:
# v(x,t) = -(x-0.5)**2 + 0.25 * exp(-t)
# w(x,t) = -(x-0.5)**2 - 0.25 * exp(-2*t)
# yields
# f(x,t) = -0.25*exp(-t) + 2 + (x-0.5)**2 - 0.25*exp(-2*t)
# g(x,t) = -0.5*exp(-2*t) - 2 - (x-0.5)**2 + 0.25*exp(-t)
from ufl import Measure, TestFunctions, split, derivative, inner, grad
from dolfinx import mesh
from dolfinx.mesh import create_unit_interval
from dolfinx.fem import functionspace, Function, Constant, form, locate_dofs_topological, dirichletbc, apply_lifting, set_bc
import dolfinx.fem.petsc as petsc
class v_exact_fun():
    def __init__(self, t):
        self.t = t
    def __call__(self, x):
        values = np.zeros((1, x.shape[1]), dtype=PETSc.ScalarType)
        values[0] = -(x[0]-0.5)**2 + 0.25*np.exp(-self.t)
        return values
class w_exact_fun():
        self.t = t
        values[0] = (x[0]-0.5)**2 - 0.25*np.exp(-2*self.t)
        return values
class f_fun():
        self.t = t
        values[0] = -0.25*np.exp(-self.t) + 2 + (x[0]-0.5)**2 - 0.25*np.exp(-2*self.t)
        return values
class g_fun():
        self.t = t
        values[0] = 0.5*np.exp(-2*self.t) - 2 - (x[0]-0.5)**2 + 0.25*np.exp(-self.t)
        return values
class PETScTSSolver:
    # F(t, u, u') = 0
    def __init__(self, ts_problem, u, bcs):
        self.u = u
        self.func_space = u.ufl_function_space()
        self.comm = self.func_space.mesh.comm
        self.u_t = Function(self.func_space)
        self.sigma_t = Constant(self.func_space.mesh, 0.0)
        self.f = ts_problem.F(self.u, self.u_t)  # Residual (linear form)
        self.f_j = self.sigma_t * ts_problem.dFdut(self.u, self.u_t) + ts_problem.dFdu(self.u, self.u_t)  # Jacobian
        self.functional_vector_petsc = petsc.create_vector(form(self.f))
        self.Jacobian_matrix_petsc = petsc.create_matrix(form(self.f_j))
        self.bcs = bcs
        self.ts = PETSc.TS().create(self.comm)
    def evalIFunction(self, ts, t, x, xdot, F):
        f.interpolate(f_fun(t))
        g.interpolate(g_fun(t))
        x.copy(self.u.x.petsc_vec)
        xdot.copy(self.u_t.x.petsc_vec)
        with F.localForm() as f_local:
            f_local.set(0.0)
        petsc.assemble_vector(F, form(self.f))
        apply_lifting(F, a=[form(self.f_j)], bcs=[self.bcs], x0=[self.u.x.petsc_vec], alpha=-1.0)
        F.ghostUpdate(addv=PETSc.InsertMode.ADD, mode=PETSc.ScatterMode.REVERSE)
        set_bc(F, bcs=self.bcs, x0=self.u.x.petsc_vec, scale=-1.0)
        F.assemble()
        return True
    def evalIJacobian(self, ts, t, x, xdot, sigma_t, J, P):
        x.ghostUpdate(addv=PETSc.InsertMode.INSERT, mode=PETSc.ScatterMode.FORWARD)
        self.u.x.petsc_vec.ghostUpdate(addv=PETSc.InsertMode.INSERT, mode=PETSc.ScatterMode.FORWARD)
        self.sigma_t.value = sigma_t
        J.zeroEntries()
        petsc.assemble_matrix(J, form(self.f_j), self.bcs)
        J.assemble()
        return True
    def solve(self, t0, dt_init, max_t, max_steps):
        y = Function(self.func_space)
        y.sub(0).interpolate(v_exact_fun(0))
        y.sub(1).interpolate(w_exact_fun(0))
        self.ts.setIFunction(self.evalIFunction, f=self.functional_vector_petsc)
        self.ts.setIJacobian(self.evalIJacobian, J=self.Jacobian_matrix_petsc)
        self.ts.setSolution(y.x.petsc_vec)
        self.ts.setTime(t0)
        self.ts.setTimeStep(dt_init)
        self.ts.setMaxTime(max_t)
        self.ts.setType(PETSc.TS.Type.BDF)
        self.ts.setTolerances(atol=1e-5, rtol=1e-5)
        self.ts.setMaxSteps(max_steps)
        self.ts.solve(y.x.petsc_vec)
        y.x.petsc_vec.copy(self.u.x.petsc_vec)
        return True
class WeakFormPDE():
    def F(self, u, u_t):
        self.v, self.w = split(u)
        self.v_t, self.w_t = split(u_t)
        F_v = self.v_t * v_test * dx + inner(grad(v_test), grad(self.v)) * dx + self.w * v_test * dx - f * v_test * dx
        F_w = self.w_t * w_test * dx + inner(grad(w_test), grad(self.w)) * dx + self.v * w_test * dx - g * w_test * dx
        return  F_v + F_w
    def dFdu(self, u, u_t):
        return derivative(self.F(u, u_t), u)
    def dFdut(self, u, u_t):
        return derivative(self.F(u, u_t), u_t)
msh = create_unit_interval(MPI.COMM_WORLD, 9)
dx = Measure("dx", domain=msh, metadata={"quadrature_degree":1})
cg1_elem = element("Lagrange", msh.basix_cell(), 1)
mix_elem = mixed_element(2 * [cg1_elem])
mix_elem_space = functionspace(msh, mix_elem)
v_space, v_dofmap = mix_elem_space.sub(0).collapse()
w_space, w_dofmap = mix_elem_space.sub(1).collapse()
v_test, w_test = TestFunctions(mix_elem_space)
u = Function(mix_elem_space)
u_t = Function(mix_elem_space)
tdim = msh.topology.dim
fdim = tdim - 1
boundary_conditions = [
    (lambda x: np.isclose(x[0], 0), 'bdry_l'),
    (lambda x: np.isclose(x[0], 1), 'bdry_r'),
dof_boundaries_v = {}
dof_boundaries_w = {}
for marker, dof_name in boundary_conditions:
    dof_boundaries_v[dof_name] = locate_dofs_topological(V=mix_elem_space.sub(0), entity_dim=fdim, entities=facets_bdry)
    dof_boundaries_w[dof_name] = locate_dofs_topological(V=mix_elem_space.sub(1), entity_dim=fdim, entities=facets_bdry)
bc_v_l = dirichletbc(value=bc_v_l_fun, dofs=dof_boundaries_v['bdry_l'])
Dirichlet_bcs = [bc_v_l]
#Dirichlet_boundary_values = {'bdry_l': 0.0}
#Dirichlet_bcs = []
#for dof_key, value in Dirichlet_boundary_values.items():
#    Dirichlet_bcs.append(dirichletbc(value=value, dofs=dof_boundaries_v[dof_key], V=mix_elem_space.sub(0)))
f = Function(v_space)
g = Function(w_space)
v_exact = Function(functionspace(msh, cg1_elem))
w_exact = Function(functionspace(msh, cg1_elem))
PETScTSSolver_instance = PETScTSSolver(WeakFormPDE(), u, Dirichlet_bcs)
PETScTSSolver_instance.solve(t0=0, dt_init=1e-10, max_t=1, max_steps=1e5)
As stated in my first post, when using zero Dirichlet boundary conditions via
Dirichlet_bcs = []
and disabling bc_v_l_fun.interpolate(v_exact_fun(t)) within evalIFunction instead of using
it works.
I would suggest having a look at:
which covers this issue in detail.
Specifically:
is not correct for a mixed space, as
should be
    dof_boundaries[dof_name] = locate_dofs_topological((mix_elem_space.sub(0),v_space) entity_dim=fdim, entities=facets_bdry)
and
should be
dirichletbc(value=bc_v_l_fun, dofs=dof_boundaries['bdry'], mix_elem_space.sub(0))
This resolved the issue, thank you.
