Function on dirichletBC in a mixed functionspace
Hi all,
Building upon other posts: splitting mixed function spaces and DirichletBC depending on both time and another function.
I would like to apply a function to a dirichletbc within a mixed function space. The following mwe runs in dolfinx v0.7.0, however resulting in 0 everywhere.
import dolfinx.fem as fem
import dolfinx.fem.petsc
import dolfinx.mesh
from dolfinx import log
my_mesh = dolfinx.mesh.create_unit_square(MPI.COMM_WORLD, 20, 20)
fdim = my_mesh.topology.dim - 1
elements = ufl.FiniteElement("CG", my_mesh.ufl_cell(), 1)
mixed_element = ufl.MixedElement([elements, elements])
V = fem.FunctionSpace(my_mesh, mixed_element)
u = fem.Function(V)
u_n = fem.Function(V)
c_1, c_2 = ufl.split(u)
v_c_1, v_c_2 = ufl.TestFunctions(V)
C1, C1_to_V = V.sub(0).collapse()
C2, C2_to_V = V.sub(1).collapse()
indices_L = dolfinx.mesh.locate_entities_boundary(
    my_mesh, fdim, lambda x: np.isclose(x[0], 0)
indices_R = dolfinx.mesh.locate_entities_boundary(
    my_mesh, fdim, lambda x: np.isclose(x[0], 1)
left_dofs_c1 = fem.locate_dofs_topological(V.sub(0), fdim, indices_L)
right_dofs_c1 = fem.locate_dofs_topological(V.sub(0), fdim, indices_R)
x = ufl.SpatialCoordinate(my_mesh)
my_bc_value = 100 * x[1]
value_function = fem.Function(C1)
bc_expr = fem.Expression(my_bc_value, C1.element.interpolation_points())
value_function.interpolate(bc_expr)
bcs = [
    fem.dirichletbc(value=value_function, dofs=left_dofs_c1),
    fem.dirichletbc(
        fem.Constant(my_mesh, PETSc.ScalarType(0)),
        right_dofs_c1,
        V.sub(0),
dx = ufl.Measure("dx", domain=my_mesh)
F = ufl.dot(ufl.grad(c_1), ufl.grad(v_c_1)) * dx
F += ufl.dot(ufl.grad(c_2), ufl.grad(v_c_2)) * dx
problem = dolfinx.fem.petsc.NonlinearProblem(F, u, bcs=bcs)
output_c1_xdmf = XDMFFile(MPI.COMM_WORLD, "fenics_MWE.xdmf", "w")
output_c1_xdmf.write_mesh(my_mesh)
solver.solve(u)
output_c1_xdmf.write_function(u.sub(0))
Is there a better way to do this?
Thanks in advance,
James
Actually, think I found a solution already, by defining the boundary dofs using a tuple of the sub space and the collapsed function space:
fem.locate_dofs_topological((V.sub(0), C1), fdim, indices_L)
and adding the function space sub space to the dirichletbc:
fem.dirichletbc(value_function, left_dofs_c1, V.sub(0))
This seemed to fix the issue.
Heres the full code for anyone interested:
import dolfinx.mesh
V = fem.functionspace(my_mesh, mixed_element)
u = fem.Function(V)
left_dofs_c1 = fem.locate_dofs_topological((V.sub(0), C1), fdim, indices_L)
bcs = [
    fem.dirichletbc(value_function, left_dofs_c1, V.sub(0)),
    fem.dirichletbc(
        right_dofs_c1,
        V.sub(0),
solver.solve(u)
output_c1_xdmf.close()
