Applying ufl.action when using ufl.MixedFunctionSpace
As the title goes, I need to calculate action when the problem involves ufl.MixedFunctionSpace as done in the example problem from scifem. I thought I could so something similar to another post using legacy dolfin by creating a solution function of the mixed space. However, it is apparently not possible in the way mixed space is created. I will appreciate if anyone could point out how it is done in this case. Below is the MWE which is the same as the scifem example with one additional line that does not work:
# # Real function spaces
# Author: Jørgen S. Dokken
# License: MIT
# In this example we will show how to use the "real" function space to solve
# a singular Poisson problem.
# The problem at hand is:
# Find $u \in H^1(\Omega)$ such that
# \begin{align}
# -\Delta u &= f \quad \text{in } \Omega, \\
# \frac{\partial u}{\partial n} &= g \quad \text{on } \partial \Omega, \\
# \int_\Omega u &= h.
# \end{align}
# ## Lagrange multiplier
# We start by considering the equivalent optimization problem:
# \begin{align}
# \min_{u \in H^1(\Omega)} J(u) = \min_{u \in H^1(\Omega)} \frac{1}{2}\int_\Omega \vert \nabla u \cdot \nabla u \vert \mathrm{d}x - \int_\Omega f u \mathrm{d}x - \int_{\partial \Omega} g u \mathrm{d}s,
# \end{align}
# such that
# \begin{align}
# \int_\Omega u = h.
# \end{align}
# We introduce a Lagrange multiplier $\lambda$ to enforce the constraint:
# \begin{align}
# \min_{u \in H^1(\Omega), \lambda\in \mathbb{R}} \mathcal{L}(u, \lambda) = \min_{u \in H^1(\Omega), \lambda\in \mathbb{R}} J(u) + \lambda (\int_\Omega u \mathrm{d}x-h).
# \end{align}
# We then compute the optimality conditions for the problem above
# \begin{align}
# \frac{\partial \mathcal{L}}{\partial u}[\delta u] &= \int_\Omega \nabla u \cdot \nabla \delta u \mathrm{d}x + \lambda\int \delta u \mathrm{d}x - \int_\Omega f \delta u ~\mathrm{d}x - \int_{\partial \Omega} g \delta u~\mathrm{d}s = 0, \\
# \frac{\partial \mathcal{L}}{\partial \lambda}[\delta \lambda] &=\delta \lambda (\int_\Omega u \mathrm{d}x -h)= 0.
# \end{align}
# We write the weak formulation:
# \begin{align}
# \int_\Omega \nabla u \cdot \nabla \delta u~\mathrm{d}x + \int_\Omega \lambda \delta u~\mathrm{d}x = \int_\Omega f \delta u~\mathrm{d}x + \int_{\partial \Omega} g v \mathrm{d}s\\
# \int_\Omega u \delta \lambda  \mathrm{d}x = h \delta \lambda .
# \end{align}
# where we have moved $\delta\lambda$ into the integral as it is a spatial constant.
# ## Implementation
# We start by creating the domain and derive the source terms $f$, $g$ and $h$ from our manufactured solution
# For this example we will use the following exact solution
# \begin{align}
# u_{exact}(x, y) = 0.3y^2 + \sin(2\pi x).
# \end{align}
from packaging.version import Version
from dolfinx.cpp.la.petsc import scatter_local_vectors, get_local_vectors
import dolfinx.fem.petsc
from scifem import create_real_functionspace, assemble_scalar
M = 20
mesh = dolfinx.mesh.create_unit_square(
    MPI.COMM_WORLD, M, M, dolfinx.mesh.CellType.triangle, dtype=np.float64
def u_exact(x):
    return 0.3 * x[1] ** 2 + ufl.sin(2 * ufl.pi * x[0])
n = ufl.FacetNormal(mesh)
g = ufl.dot(ufl.grad(u_exact(x)), n)
f = -ufl.div(ufl.grad(u_exact(x)))
h = assemble_scalar(u_exact(x) * ufl.dx)
# We then create the Lagrange multiplier space
R = create_real_functionspace(mesh)
# Next, we can create a mixed-function space for our problem
if dolfinx.__version__ == "0.8.0":
    u = ufl.TrialFunction(V)
    lmbda = ufl.TrialFunction(R)
    du = ufl.TestFunction(V)
    dl = ufl.TestFunction(R)
elif Version(dolfinx.__version__) >= Version("0.9.0.0"):
    W = ufl.MixedFunctionSpace(V, R)
    u, lmbda = ufl.TrialFunctions(W)
    du, dl = ufl.TestFunctions(W)
    raise RuntimeError("Unsupported version of dolfinx")
# We can now define the variational problem
zero = dolfinx.fem.Constant(mesh, dolfinx.default_scalar_type(0.0))
a00 = ufl.inner(ufl.grad(u), ufl.grad(du)) * ufl.dx
a01 = ufl.inner(lmbda, du) * ufl.dx
a10 = ufl.inner(u, dl) * ufl.dx
L0 = ufl.inner(f, du) * ufl.dx + ufl.inner(g, du) * ufl.ds
L1 = ufl.inner(zero, dl) * ufl.dx
a = dolfinx.fem.form([[a00, a01], [a10, None]])
L = dolfinx.fem.form([L0, L1])
# Note that we have defined the variational form in a block form, and
# that we have not included $h$ in the variational form. We will enforce this
# once we have assembled the right hand side vector.
# We can now assemble the matrix and vector
A = dolfinx.fem.petsc.assemble_matrix_block(a)
b = dolfinx.fem.petsc.assemble_vector_block(L, a, bcs=[])
# Next, we modify the second part of the block to contain `h`
# We start by enforcing the multiplier constraint $h$ by modifying the right hand side vector
    maps = [(V.dofmap.index_map, V.dofmap.index_map_bs), (R.dofmap.index_map, R.dofmap.index_map_bs)]
    maps = [(Wi.dofmap.index_map, Wi.dofmap.index_map_bs) for Wi in W.ufl_sub_spaces()]
b_local = get_local_vectors(b, maps)
b_local[1][:] = h
scatter_local_vectors(
        b,
        b_local,
        maps,
b.ghostUpdate(addv=PETSc.InsertMode.INSERT, mode=PETSc.ScatterMode.FORWARD)
# We can now solve the linear system
ksp = PETSc.KSP().create(mesh.comm)
ksp.setOperators(A)
ksp.setType("preonly")
pc = ksp.getPC()
pc.setType("lu")
xh = dolfinx.fem.petsc.create_vector_block(L)
ksp.solve(b, xh)
xh.ghostUpdate(addv=PETSc.InsertMode.INSERT, mode=PETSc.ScatterMode.FORWARD)
# Finally, we extract the solution u from the blocked system and compute the error
uh = dolfinx.fem.Function(V, name="u")
x_local = get_local_vectors(xh, maps)
uh.x.array[: len(x_local[0])] = x_local[0]
uh.x.scatter_forward()
# to use action, first create a function object of W
wh = dolfinx.fem.Function(W)
act = ufl.action(a, wh)
This leads to the following error:
In [8]: wh = dolfinx.fem.Function(W)
Cell In[8], line 1
----> 1 wh = dolfinx.fem.Function(W)
File ~/miniconda3/envs/fenics-0.9/lib/python3.12/site-packages/dolfinx/fem/function.py:319, in Function.__init__(self, V, x, name, dtype)
    315     if dtype is None:
    316         dtype = default_scalar_type
    318 assert np.issubdtype(
--> 319     V.element.dtype, np.dtype(dtype).type(0).real.dtype
    320 ), "Incompatible FunctionSpace dtype and requested dtype."
    322 # Create cpp Function
    323 def functiontype(dtype):
AttributeError: 'MixedFunctionSpace' object has no attribute 'element'
I have made a pull request to make it possible to use actions on MixedFunctionSpace at: Add `ufl.action` for MixedFunctionSpace by jorgensd · Pull Request #351 · FEniCS/ufl · GitHub
Apart from action, is it currently possible (directly or otherwise) to do dolfinx.fem.Function() on a MixedFunctionSpace object?
Not directly, you would make a function in each of the spaces, rather than a single function.
You can use F_action= ufl.replace(form, {u:uh}) to replace a trial function from a mixed space with a coefficient from the sub-space.
