Hi everyone,
I have constructed my mesh in this way:
import os
import math
from dolfinx import default_real_type, log, mesh
from dolfinx.fem import Function, functionspace, Expression
from dolfinx.fem.petsc import NonlinearProblem, LinearProblem
from dolfinx.io import XDMFFile, gmshio
from ufl import dx, grad, inner, div,dot
# Save all logging to file
log.set_output_file("log.txt")
# Next, various model parameters are defined:
dt = 1.0e-3 # time step
try:
import gmsh # type: ignore
except ImportError:
import sys
print("This demo requires gmsh to be installed")
sys.exit(0)
def gmsh_circle(model: gmsh.model, name: str) -> gmsh.model:
"""Create a Gmsh model of a circle.
model.add(name)
model.setCurrent(name)
gmsh.option.setNumber("Mesh.CharacteristicLengthFactor", 1.5)
circle = model.occ.addCircle(0, 0, 0, 1, tag=1)
# Synchronize OpenCascade representation with gmsh model
model.occ.synchronize()
# Add physical marker for cells. It is important to call this
# function after OpenCascade synchronization
model.add_physical_group(dim=1, tags=[circle])
# Generate the mesh
model.mesh.generate(dim=1)
model.mesh.setOrder(2)
return model
def create_mesh(comm: MPI.Comm, model: gmsh.model, name: str, filename: str, mode: str):
"""Create a DOLFINx from a Gmsh model and output to file.
msh, ct, ft = gmshio.model_to_mesh(model, comm, rank=0,gdim=2)
msh.name = name
ct.name = f"{msh.name}_cells"
ft.name = f"{msh.name}_facets"
with XDMFFile(msh.comm, filename, mode) as file:
msh.topology.create_connectivity(0, 1)
file.write_mesh(msh)
file.write_meshtags(ct, msh.geometry, geometry_xpath=f"/Xdmf/Domain/Grid[@Name='{msh.name}']/Geometry")
file.write_meshtags(ft, msh.geometry, geometry_xpath=f"/Xdmf/Domain/Grid[@Name='{msh.name}']/Geometry")
gmsh.option.setNumber("General.Terminal", 0)
# Create model
model = gmsh.model()
model = gmsh_circle(model, "circle")
model.setCurrent("circle")
create_mesh(MPI.COMM_SELF, model, "circle", f"out_gmsh/mesh_rankCircle_{MPI.COMM_WORLD.rank}.xdmf", "w")
with XDMFFile(MPI.COMM_WORLD, "out_gmsh/mesh_rankCircle_0.xdmf", "r") as xdmf:
mesh = xdmf.read_mesh(name="circle")
gmsh.finalize
P1 = element("Lagrange", mesh.basix_cell(), 2, gdim=2)
P2 = element("Lagrange", mesh.basix_cell(), 2, shape=(mesh.geometry.dim,), gdim=2)
ME = functionspace(mesh, mixed_element([P1, P1], gdim=2))
V = functionspace(mesh, P2)
This is a manifold of geometrical dimension 2 but topological dimension 1. Is there a way to compute the area enclosed by this curve (in this case, it is just a circle, but the mesh evolves over time)?
Than you
