When trying to create mesh using gmsh I am getting PETSC ERROR
from dolfinx.io import (VTXWriter, distribute_entity_data, gmshio)
from dolfinx import default_scalar_type, plot
from dolfinx.fem import (functionspace, dirichletbc)
# Physical parameters
D = 1
Ht = 1.62 # height till top
Hb = 1.9 # height till bottom
L = 6
H = Ht+Hb
c_x = 0
c_y = 0
r = D/2
# Numerical parameters
resolution = 0.1  # Target characteristic length factor #0.05
# EPS = np.finfo(float).eps  # Machine epsilon for float
model_rank = 0
mesh_comm = MPI.COMM_WORLD
gdim=2
# Create gmsh geometry
# Create channel
rectangle = gmsh.model.occ.addRectangle(-L/2, -Hb, 0, L, H)
# Create circle
obstacle = gmsh.model.occ.addDisk(c_x, c_y, 0, r, r)
gmsh.model.occ.cut([(gdim, rectangle)], [(gdim, obstacle)])
gmsh.model.occ.synchronize()
# # Set mesh resolution
gmsh.option.setNumber("Mesh.CharacteristicLengthFactor", resolution)
gmsh.option.setNumber("Mesh.Algorithm", 8)
gmsh.option.setNumber("Mesh.RecombinationAlgorithm", 2)
gmsh.option.setNumber("Mesh.RecombineAll", 1)
gmsh.option.setNumber("Mesh.SubdivisionAlgorithm", 1)
gmsh.model.mesh.setOrder(2)
gmsh.write("mesh2.msh")
# # gmsh.fltk().run()
# # Convert gmsh mesh to dolfinx mesh
mesh_obj, _, _ = gmshio.model_to_mesh(gmsh.model, mesh_comm, model_rank, gdim=gdim)
gmsh.finalize()
Getting this error
Info    : Meshing 1D...
Info    : [  0%] Meshing curve 5 (Ellipse)
Info    : [ 20%] Meshing curve 6 (Line)
Info    : [ 40%] Meshing curve 7 (Line)
Info    : [ 60%] Meshing curve 8 (Line)
Info    : [ 80%] Meshing curve 9 (Line)
Info    : Done meshing 1D (Wall 0.000345293s, CPU 9e-05s)
Info    : Meshing 2D...
Info    : Meshing surface 1 (Plane, Frontal-Delaunay for Quads)
[0]PETSC ERROR: or see https://petsc.org/release/faq/#valgrind
[0]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors
MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
with errorcode 59.
NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
You may or may not see output from other processes, depending on
exactly when Open MPI kills them.
Process ended with exit code 59.
Drop every FEniCSx related import and command to confirm that the error is still there.
D = 1
L = 6
H = Ht+Hb
c_x = 0
c_y = 0
r = D/2
model_rank = 0
gdim=2
# Create channel
# Create circle
gmsh.finalize()
and get
[ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x3f5d0) [0x7f54bc5b85d0]
[ 1] /lib/x86_64-linux-gnu/libgmsh.so.4.12(_ZNK14MElementOctree4findEdddib+0x1e) [0x7f54b2cb720e]
[ 2] /lib/x86_64-linux-gnu/libgmsh.so.4.12(_ZNK14backgroundMesh8getAngleEddd+0x5a) [0x7f54b2e1939a]
[ 3] /lib/x86_64-linux-gnu/libgmsh.so.4.12(_ZN5MTri3C2EP9MTriangledP8SMetric3P13bidimMeshDataP5GFace+0xa7b) [0x7f54b2d646cb]
[ 4] /lib/x86_64-linux-gnu/libgmsh.so.4.12(_Z33buildMeshGenerationDataStructuresP5GFaceRSt3setIP5MTri314compareTri3PtrSaIS3_EER13bidimMeshData+0x1333) [0x7f54b2d76633]
[ 5] /lib/x86_64-linux-gnu/libgmsh.so.4.12(_Z25bowyerWatsonFrontalLayersP5GFacebPSt3mapIP7MVertexS3_St4lessIS3_ESaISt4pairIKS3_S3_EEEPS1_IS3_7SPoint2S5_SaIS6_IS7_SC_EEE+0x1ba) [0x7f54b2d6a23a]
[ 6] /lib/x86_64-linux-gnu/libgmsh.so.4.12(+0x737077) [0x7f54b2d37077]
[ 7] /lib/x86_64-linux-gnu/libgmsh.so.4.12(_ZN9meshGFaceclEP5GFaceb+0x3d3) [0x7f54b2d40e53]
[ 8] /lib/x86_64-linux-gnu/libgmsh.so.4.12(_ZN5GFace4meshEb+0x67) [0x7f54b2b0cad7]
[ 9] /lib/x86_64-linux-gnu/libgmsh.so.4.12(+0x716c8b) [0x7f54b2d16c8b]
[10] /lib/x86_64-linux-gnu/libgomp.so.1(GOMP_parallel+0x46) [0x7f54b8021866]
[11] /lib/x86_64-linux-gnu/libgmsh.so.4.12(_Z12GenerateMeshP6GModeli+0xa6f) [0x7f54b2d1ed5f]
[12] /lib/x86_64-linux-gnu/libgmsh.so.4.12(_ZN6GModel4meshEi+0x29) [0x7f54b2b5f2d9]
[13] /lib/x86_64-linux-gnu/libgmsh.so.4.12(_ZN4gmsh5model4mesh8generateEi+0x34) [0x7f54b29993b4]
[14] /lib/x86_64-linux-gnu/libgmsh.so.4.12(gmshModelMeshGenerate+0x18) [0x7f54b34cc328]
Therefore, this is an error in gmsh, and not in dolfinx. Hence support must be asked on the gmsh support channel Issues · gmsh / gmsh · GitLab and not here.
