Argument out of range - PETSc error
My goal is to solve this problem:
\begin{align*} 0 &= dif1 * \nabla u1 + mixed1 * u1 - theta1 * u2 \\ 0 &= dif2 * \nabla u2 + mixed1 * u2 + theta2 * u1 \end{align*}
where
\begin{align*} dif1,\ dif2 &= 0.1 \\ mixed1,\ mixed2 &= 0.1 \\ theta1, theta2 &= 0.1 \end{align*}
and the boundary conditions are
\begin{align*} u1 &= 2.0 \quad {\rm on} \ \Gamma_{D} \\ u2 &= 0.0 \quad {\rm on} \ \Gamma_{D} \\ \end{align*}
I wrote the following code
# Mesh
mesh = UnitSquareMesh(32, 32)
# Finite Element
P1 = FiniteElement('Lagrange', mesh.ufl_cell(), 1)
V = FunctionSpace(mesh, 'Lagrange', 1)
W = FunctionSpace(mesh, P1*P1)
# Boundary
def boundary(x):
  return x[0] < DOLFIN_EPS or x[1] < DOLFIN_EPS \
    or x[0] > 1.0 - DOLFIN_EPS or x[1] > 1.0 - DOLFIN_EPS
# Condition
u10 = Constant(2.0)
u20 = Constant(0.0)
bc1 = DirichletBC(W.sub(0), u10, boundary)
bc2 = DirichletBC(W.sub(1), u20, boundary)
bcs = [bc1, bc2]
# Problem
# Coefficients
mixed1 = Constant(0.1)
mixed2 = Constant(0.1)
dif1 = Constant(0.1)
dif2 = Constant(0.1)
theta1 = Constant(0.1)
theta2 = Constant(0.1)
# Test - trial functions
(u1, u2) = TrialFunctions(W)
(v1, v2) = TestFunctions(W)
w = Function(W)
u1 = w.sub(0)
u2 = w.sub(1)
# Variational formulation
a1 = dif1*dot(grad(u1), grad(v1))*dx
f1 = mixed1*u1 - theta1*u2
L1 = f1*v1*dx
F1 = a1 - L1
a2 = dif2*dot(grad(u2), grad(v2))*dx
f2 = mixed2*u2 + theta2*u1
L2 = f2*v2*dx
F2 = a2 - L2
F = F1 + F2
# Solution
solve(F == 0, w, bcs)
It gives the following error:
*** Error:   Unable to successfully call PETSc function 'MatSetValuesLocal'.
*** Reason:  PETSc error code is: 63 (Argument out of range).
*** Where:   This error was encountered inside /build/dolfin-LDAJTl/dolfin-2019.1.0/dolfin/la/PETScMatrix.cpp.
*** Process: 0
I read the former posts, but couldn’t solve the issue. Any help would be appreciated.
  1. Which argument is out of range?
  2. How the code can be fixed?
Thanks!
Consider the following adjusted code, using mixed-element:
# Mesh
# Finite Element
W = FunctionSpace(mesh, MixedElement([P1,P1]))
# Boundary
def boundary(x):
# Condition
u10 = Constant(2.0)
u20 = Constant(0.0)
bcs = [bc1, bc2]
# Problem
# Coefficients
w = Function(W)
u1, u2 = split(w)
L1 = f1*v1*dx
F1 = a1 - L1
L2 = f2*v2*dx
F2 = a2 - L2
F = F1 + F2
# Solution
