Error: Unable to successfully call PETSc function 'MatSetValuesLocal'. Reason: PETSc error code is: 63 (Argument out of range)
I am trying to solve a non-linear variational problem, but I get:
*** Error: Unable to successfully call PETSc function ‘MatSetValuesLocal’.
*** Reason: PETSc error code is: 63 (Argument out of range).
*** Where: This error was encountered inside /build/dolfin-cZGj9S/dolfin-2019.2.0~git20200629.946dbd3/dolfin/la/PETScMatrix.cpp.
*** Process: 0
Here is my code:
mesh = UnitSquareMesh(4,4)
W = VectorFunctionSpace(mesh, 'CG', 1)
u, v, du = Function(W), TestFunction(W), TrialFunction(W)
top = CompiledSubDomain("near(x[1], 1) && on_boundary")
bot = CompiledSubDomain("near(x[1], -1) && on_boundary")
bcbot= DirichletBC(W, Constant((0.0,0.0)), bot)
bctop = DirichletBC(W.sub(1), Constant(0.1), top)
bc_u = [bcbot, bctop]
lmbda, mu = 120, 80
# Constituive functions
    return sym(grad(u))
def sigma(u):
    E = psi(u)
    F = Identity(len(u)) + sym(grad(u))
    F = variable(F)
    return diff(E, F)
def psi(u):
    return 0.5*lmbda*(tr(epsilon(u)))**2 + mu*inner(epsilon(u), epsilon(u))
E_du = inner(grad(v), sigma(u))*dx
J  = derivative(E_du, u, du)
p_disp = NonlinearVariationalProblem(E_du, u, bc_u, J)
solver_disp = NonlinearVariationalSolver(p_disp)
solver_disp.solve()
Any help is much appreciated!
THe issue is that the operation diff(E, F) returns 0, as psi is not a function of F. Have you considered the hyperelasticity demo: Hyperelasticity — DOLFIN documentation ?
Thank you so much!
Yes, that demo resolved the issue!
