Hi everyone, I am working through the nonlinear Poisson equation tutorial and encountering an ArityMismatch error when trying to use conjugated test functions with the complex PETSc library.
Setup
- FEniCS version: DOLFINx 0.8.0.
- Installation:
mamba install -c conda-forge fenics-dolfinx mpich pyvistafollowed by complex PETSc installation. - Platform: Linux (Ubuntu 24.04.2 LTS).
- PETSc: Complex version.
Problem Description
I need to use complex PETSc for a complex-valued non-linear PDE, which requires conjugated test functions in the variational form. However, when I try to create a NonlinearProblem with ufl.conj(v) in the residual form, I get an ArityMismatch error, when trying to reproduce the nonlinear Poisson equation.
uh = fem.Function(V)
# This works with real PETSc but fails with complex PETSc
F = q(uh) * ufl.inner(ufl.grad(uh), ufl.grad(ufl.conj(v))) * ufl.dx - f * ufl.conj(v) * ufl.dx
# This line triggers the error
problem = NonlinearProblem(F, uh, bcs=[bc])
Error Message
ArityMismatch Traceback (most recent call last)
Cell In[5], line 2
1 # Create and solve nonlinear problem
----> 2 problem = NonlinearProblem(F, uh, bcs=[bc])
[... traceback continues ...]
File ~/anaconda3/envs/fenics_env/lib/python3.11/site-packages/ufl/algorithms/check_arities.py:57, in ArityChecker.sum(self, o, a, b)
55 """Apply to sum."""
56 if a != b:
---> 57 raise ArityMismatch(
58 f"Adding expressions with non-matching form arguments {_afmt(a)} vs {_afmt(b)}."
59 )
60 return a
ArityMismatch: Adding expressions with non-matching form arguments ('conj(v_0)',) vs ('v_0',)
What I’ve Tried
- Without conjugation:
F = q(uh) * ufl.inner(ufl.grad(uh), ufl.grad(v)) * ufl.dx - f * v * ufl.dx, raising similar error. - Consistent conjugation: Ensuring all test function terms use
ufl.conj(v). - Real part wrapper:
F = ufl.real(...)around the entire form. - Separated forms: Defining bilinear and linear parts separately.
- Cache clearing: Removed
~/.cache/fenics/*to resolve subsequent timeout errors.
The error suggests the FFCx form compiler is seeing inconsistent argument structures when mixing conjugated and non-conjugated terms in the Newton’s method, but I’m not sure how to resolve this properly while maintaining the mathematical correctness for complex PETSc.
Is there a proper way to handle conjugated test functions in nonlinear forms with complex PETSc in DOLFINx 0.8.0 (e.g., providing explicitly the variational form of the Jacobian)?
Should I be using a different approach entirely for complex-valued nonlinear problems?
Any guidance would be greatly appreciated!
