Hi!
I’m running into an AssertionError while trying to run the code below, which is an adaptation from an example I found online. I’m assuming this regards the indices of an as_tensor() definition, as you can see in the error message below the code. Please, note I’m using Multiphenics library.
from ufl import *
from multiphenics import *
import numpy
a=0.1;
t=a/10;
####PML definition
def compProd(a1,b1,a2,b2):
x1=a1*a2-b1*b2;
x2=a1*b2+a2*b1;
return (x1, x2)
class LR(UserExpression):
def eval(self, value, x):
a=0.1;t=a/10;
b1 = numpy.abs(x[0])-a/2; f1=10*(b1+numpy.abs(b1))/(2*t);
b2 = numpy.abs(x[1])-a/2; f2=10*(b2+numpy.abs(b2))/(2*t);
l1R=1+f1;l1I=-f1;
l2R=1+f2;l2I=-f2;
value[0] = l1R/(pow(l1R,2)+pow(l1I,2));
value[3] = l2R/(pow(l2R,2)+pow(l2I,2));
value[1] = 0;
value[2] = 0;
def value_shape(self):
return (2,2)
class LI(UserExpression):
a=0.1;t=a/10;
l1R=1+f1;l1I=-f1;
l2R=1+f2;l2I=-f2;
value[0] = -l1I/(pow(l1R,2)+pow(l1I,2));
value[3] = -l2I/(pow(l2R,2)+pow(l2I,2));
value[1] = 0;
value[2] = 0;
return (2,2)
class lR(Expression):
a=0.1;t=a/10;
l1R=1+f1;l1I=-f1;
l2R=1+f2;l2I=-f2;
value[0], temp = compProd(l1R,l1I,l2R,l2I);
# def value_shape(self):
# return (1,)
class lI(Expression):
a=0.1;t=a/10;
l1R=1+f1;l1I=-f1;
l2R=1+f2;l2I=-f2;
temp, value[0] = compProd(l1R,l1I,l2R,l2I);
# return (1,)
class Middle(SubDomain):
return (near(x[1], 0) and between(x[0], (-1,1)))
LambdaR = LR()
LambdaI = LI()
LLR = lR
LLI = lI
####Geometry and mesh
x_1, y_1 = -6.0, -4.0
x_2, y_2 = 6.0, 4.0
nx, ny = 300, 200
mesh = RectangleMesh(Point(x_1, y_1), Point(x_2, y_2), nx, ny)
boundaries = MeshFunction("size_t", mesh, 1)
boundaries.set_all(0)
Middle().mark(boundaries, 1)
####Material properties
E, rho, nu = 300E+8, 8000, 0.3
frequency=50000
omega=2*numpy.pi*frequency
lam = E*nu/((1+nu)*(1-2*nu))
mu = E/(2*(1+nu))
i,j,k,l = indices(4)
delta = Identity(2)
C=as_tensor((lam*(delta[i,j]*delta[k,l])+mu*(delta[i,k]*delta[j,l]+delta[i,l]*delta[j,k])),(i,j,k,l))
####Space of functions
V = VectorFunctionSpace(mesh, "CG", 1)
Vcomplex = BlockFunctionSpace([V, V], restrict=[None, None])
#Applying the Boundary conditions
source = [DirichletBC(Vcomplex.sub(0), Constant((1.0, 0.0)), boundaries, 1), DirichletBC(Vcomplex.sub(1), Constant((0.0, 0.0)), boundaries, 1)]
bc=source
#Real and Imaginary parts of the trial and test functions
(uR, uI) = BlockTrialFunction(Vcomplex)
(wR, wI) = BlockTestFunction(Vcomplex)
#Weak form
strainR=0.5*(as_tensor((Dx(uR[i],k)*LambdaR[k,j]),(i,j,k)) + as_tensor((Dx(uR[k],i)*LambdaR[j,k]),(i,j))) - 0.5*(as_tensor((Dx(uI[i],k)*LambdaI[k,j]),(i,j)) + as_tensor((Dx(uI[k],i)*LambdaI[j,k]),(i,j,k)))
strainI=0.5*(as_tensor((Dx(uR[i],k)*LambdaI[k,j]),(i,j)) + as_tensor((Dx(uR[k],i)*LambdaI[j,k]),(i,j))) + 0.5*(as_tensor((Dx(uI[i],k)*LambdaR[k,j]),(i,j)) + as_tensor((Dx(uI[k],i)*LambdaR[j,k]),(i,j)))
tempR=LLR*LambdaR-LLI*LambdaI
tempI=LLR*LambdaI+LLI*LambdaR
sR=as_tensor((C[i,j,k,l]*strainR[k,l]),[i,j])
sI=as_tensor((C[i,j,k,l]*strainI[k,l]),[i,j])
stressR=as_tensor((sR[i,j]*tempR[j,k]),(i,k)) - as_tensor((sI[i,j]*tempI[j,k]),(i,k))
stressI=as_tensor((sR[i,j]*tempI[j,k]),(i,k)) + as_tensor((sI[i,j]*tempR[j,k]),(i,k))
F=omega**2*rho*(dot((LLR*uR-LLI*uI),wR)+dot((LLR*uI+LLI*uR),wI))*dx-(inner(stressR, grad(wR))+inner(stressI, grad(wI)))*dx
a, L = lhs(F), rhs(F)
The error
AssertionError Traceback (most recent call last)
<ipython-input-5-d842c862a222> in <module>
130 #Weak form
131 ###########################################################
--> 132 strainR=0.5*(as_tensor((Dx(uR[i],k)*LambdaR[k,j]),(i,j,k)) + as_tensor((Dx(uR[k],i)*LambdaR[j,k]),(i,j))) - 0.5*(as_tensor((Dx(uI[i],k)*LambdaI[k,j]),(i,j)) + as_tensor((Dx(uI[k],i)*LambdaI[j,k]),(i,j,k)))
133 strainI=0.5*(as_tensor((Dx(uR[i],k)*LambdaI[k,j]),(i,j)) + as_tensor((Dx(uR[k],i)*LambdaI[j,k]),(i,j))) + 0.5*(as_tensor((Dx(uI[i],k)*LambdaR[k,j]),(i,j)) + as_tensor((Dx(uI[k],i)*LambdaR[j,k]),(i,j)))
134
/usr/local/lib/python3.6/dist-packages/ufl/tensors.py in as_tensor(expressions, indices)
258
259 # Make a tensor from given scalar expression with free indices
--> 260 return ComponentTensor(expressions, indices)
261
262
/usr/local/lib/python3.6/dist-packages/ufl/tensors.py in __init__(self, expression, indices)
140 fi, fid, sh = remove_indices(expression.ufl_free_indices,
141 expression.ufl_index_dimensions,
--> 142 [ind.count() for ind in indices])
143 self.ufl_free_indices = fi
144 self.ufl_index_dimensions = fid
/usr/local/lib/python3.6/dist-packages/ufl/index_combination_utils.py in remove_indices(fi, fid, rfi)
125 break
126
--> 127 assert None not in shape
128
129 # Unpack into two tuples
AssertionError:
Can somebody please explain this error and how to fix it?
Many thanks!
