Assemble forms with test functions
I’m trying to compute the integral of fv, where f is a function defined in a finite element function space V, and v is the test function of the same space.
In Python, this is very straightforward and works correctly for any degree I specify. Here is a minimal working example:
from dolfinx import fem, mesh
from ufl import dx
degree = 3
msh = mesh.create_interval(comm=MPI.COMM_WORLD, nx=10, points=(0.0, 1.0))
V = fem.functionspace(msh, ("Lagrange", degree))
f = 10 * ufl.exp(-((x[0] - 0.5) ** 2) / 0.01)
L = fem.form(f * v * dx)
print(fem.assemble_scalar(L))
No matter what degree I choose, this implementation runs smoothly.
However, when I attempt a similar approach using the C++ interface, I encounter issues. I construct the form using UFL and Basix as follows:
from basix.ufl import element
from basix import LagrangeVariant
from ufl import *
cell = "interval"
degree_cg = 3
e = element("Lagrange", cell, degree_cg, LagrangeVariant.equispaced)
coord = element("Lagrange", cell, 1, shape=(1,))
mesh = Mesh(coord)
V = FunctionSpace(mesh, e)
f = Coefficient(V)
a = f * v * dx
Then, in C++, I create and assemble the form as:
auto a = std::make_shared<Form<T,U>>(fem::create_form<T,U>(*form_test_1D_P3_gauss1, {V_}, {{"f", Ff_}}, {}, {}));
T g = dolfinx::fem::assemble_scalar(*a);
This works fine for polynomial degrees 1 and 2. However, when I use degree 3, I encounter the following error:
[0]PETSC ERROR: or see https://petsc.org/release/faq/#valgrind and https://petsc.org/release/faq/
Abort(59) on node 0 (rank 0 in comm 0): application called MPI_Abort(MPI_COMM_WORLD, 59) - process 0
It seems like the issue is specific to higher-order elements, possibly related to quadrature or DOF mapping. I’d appreciate any insights into what might be causing this or suggestions for resolving it.
This may show up my utter ignorance… but I’m actually puzzled as to why your original example assembles a scalar value
from ufl import dx
degree = 3
The linear formulation in L should be defined as the vector
\int_{k} f \, v \, \mathrm{d}\vec{x} \quad \forall k \in \mathcal{T}^h(\Omega)
where \mathcal{T}^h is the mesh of your domain \Omega and k is an element in the mesh.
I suspect DOLFINx is not performing an arity check in your simulation. I’d be careful as I think the “scalar quantity” you’re computing is meaningless.
I’m sorry I didn’t clearly state my purpose.
Actually, I’m checking the error of the Gauss’s law, for example, in 1D it should be:
\partial_xE = \rho
because I solved it in the weak form, so the above conclusion also only hold in the weak form:
-(E_h,\partial_x\phi) = (\rho_h,\phi),\qquad\forall\phi\in V
And what I wanted to do is compute the values of the two terms on the two sides of equation, and compare the difference, that’s why I have the test function in the form.
Actually, it used to work well, but recently I updated my DOLFINx from version v0.6.0 to v.7.3, then the problems happen. I have attached my codes before:
import basix
from basix.ufl_wrapper import create_element, create_vector_element
from ufl import Coefficient, TestFunction, TrialFunction, dx, CellVolume, Mesh, div, grad, dot
degree_cg = 3
cell = "interval"
element = create_element("Lagrange",cell, degree_cg, basix.LagrangeVariant.equispaced)
coord_element = create_vector_element("DG", cell, 3)
mesh = Mesh(coord_element)
v = TestFunction(element)
rho = Coefficient(element)
gauss = -rho * v * dx
and
auto gauss = std::make_shared<Form<T>>(fem::create_form<T>(*form_Maxwell_1D_Q3_gauss, {V}, {{"rho", rho_}}, {}, {}));
I can see there are difference between, but not sure how can I change it, since I followed the demos.
Acutally the scalar quantity is just what I need, since I want to compute the error, but I don’t know why it doesn’t work for P3 elements.
The problem is that the equation above does not yield a scalar quantity.
As you need to test for all \phi_i\in V_h, you get a vector b_i with entries
\begin{pmatrix}(\rho, \phi_0)\\ (\rho, \phi_1)\\ \vdots \\(\rho, \phi_{N-1})\end{pmatrix}
When you mean computing the error between the two, you should compute the two vectors, and then compare them element by element, or equivalently assemble the difference into a single vector, and then perform an l_2 norm.
Ok I see, yes you are right, the test function is not a single function, so I should get a vector instead of a scalar.
