Assemble with dolfin VS dolfinx
Hello everyone,
I can’t figure out why I have such big difference between dolfin VS dolfinx with the assemble function.
I am using RT elements. (I have not the problem with CG or DG elements).
Here is a code snippet to reproduce my problem:
import basix
# Using Dolfin
import dolfin as dlf
mesh_dlf = dlf.BoxMesh(dlf.Point(0.0, 0.0, 0.0),
                dlf.Point(1.0, 1.0, 1.0),
                10,10,10)
V_dlf = dlf.FunctionSpace(mesh_dlf, "RT", 1)
f_dlf = dlf.Function(V_dlf)
f_dlf.vector().set_local(np.ones(V_dlf.dim()))
vol_dlf = dlf.assemble(dlf.Constant(1)  * dlf.Measure('dx', domain=mesh_dlf))
res_dlf = dlf.assemble(dlf.dot(f_dlf,f_dlf)**(1/2) * dlf.dx)
print(vol_dlf)
print(res_dlf)
# Using Dolfinx
import dolfinx as dlfx
mesh_dlfx = dlfx.mesh.create_unit_cube(MPI.COMM_WORLD,
                                  10,
                                  10,
                                  10,
                                  dlfx.mesh.CellType.tetrahedron)
V_dlfx = dlfx.fem.functionspace(mesh_dlfx,("RT",1))
f_dlfx = dlfx.fem.Function(V_dlfx)
f_dlfx.vector.setArray(np.ones(f_dlfx.vector.size))
vol_dlfx = dlfx.fem.assemble_scalar(dlfx.fem.form(dlfx.fem.Constant(mesh_dlfx, 1.0) * ufl.dx))
res_dlfx = dlfx.fem.assemble_scalar(dlfx.fem.form(ufl.dot(f_dlfx,f_dlfx)**(1/2) * ufl.dx))
print(vol_dlfx)
print(res_dlfx)
I first compute the volume of the domain just to check if everything is ok (and it is indeed: vol_dlf ~ vol_dlfx ~ 1).
But I have a big difference when comparing the norm of the function on the domain:
res_dlf = 141.42
res_dlfx = 312.47
Is it related to different lagrangevariant used ? The default lagrangevariant for RT with dolfinx is “legendre”, but I can’t find the one used with dolfin.
Thanks :slight_smile:
This is because setting dof values to a RT array doesn’t really make sense.
You should be quite careful with this, as the degrees of freedom relate to vector basis functions.
Here is a way to illustrate the same, but with an actually well defined function (the constant vector (2,1,3), you could change this to (1,1,1) if you want to)
# # Using Dolfinx
try:
    def f(x):
        values = np.zeros((3, x.shape[1]))
        values[0] = 2
        values[1] = 1
        values[2] = 3
        return values
                                           10,
                                           10,
                                           10,
    V_dlfx = dlfx.fem.functionspace(mesh_dlfx, ("RT", 1))
    f_dlfx.interpolate(f)
        dlfx.fem.form(ufl.dot(f_dlfx, f_dlfx)**(1/2) * ufl.dx))
    print("dolfinx")
    print(f"{vol_dlfx=}")
    print(f"{res_dlfx=}")
except ImportError:
    # Using Dolfin
                           10, 10, 10)
    f_dlf.interpolate(dlf.Expression(("2", "1", "3"), degree=1))
    res_dlf = dlf.assemble(dlf.dot(f_dlf, f_dlf)**(1/2) * dlf.dx)
    print("legacy dolfin")
    print(f"{vol_dlf=}")
    print(f"{res_dlf=}")
yields
dolfinx
vol_dlfx=0.9999999999999232
res_dlfx=3.7416573867708562
and
legacy dolfin
vol_dlf=0.9999999999999232
res_dlf=3.74165738677434
Thank you Dokken for your quick reply !
Then, how can I evaluate a RT basis function ?
I used to do :
V = dlfx.functionspace(mesh,("RT",1))
f = dlfx.Function(V)
values = np.zeros(f.vector.size)
values[5] = 1
f.vector.setArray(values)
to evaluate the 5th basis function for example
What do you want to use the basis function for?
I’ve covered how to compute the basis function (and push forward action) for N1curl elements at: Advanced finite elements — FEniCS Workshop
where the covariant piola map is used to map the basis to a given physical cell.
For RT you would need to contravariant piola map.
Note that all of this can be done with
expr = dolfinx.fem.Expression(ufl.TestFunction(V), insert_points_on_reference_element_here)
# select what cell to evaluate in
cells = np.array([1], dtype=np.int32)
print(expr.eval(mesh, cells))
which will give you the basis functions in physical space evaluated at the insert_points_on_reference_element_here pushed forward to the physical cell.
Interresting documentation, thank’s !
Actually, I want to evaluate an expression for each dof one by one, in order to build a vector G of len=n_dofs, where the ith value correspond to the eval of the expression for the ith dof (dof_i = 1, other_dof = 0)
So I was doing this:
def eval_my_fun(dof_i, vec, f, fxyz):
    vec[dof_i] = 1
    f.vector.setArray(vec)
    # Integrate over all the domain
    dx = ufl.Measure("dx",
                     domain=mesh,
                     metadata={"quadrature_degree": 8})
    res = dlfx.fem.assemble_scalar(dlfx.fem.form((ufl.cross(fxyz,f)[2] / ufl.dot(fxyz,fxyz)**(3/2)) * dx))
    vec[dof_i] = 0
    return res
V = dlfx.fem.functionspace(mesh,("RT",1))
f = dlfx.fem.Function(V)
n_dofs = f.vector.size
u_e = u_expression(c)
f_xyz = dlfx.fem.Function(V)
f_xyz.interpolate(u_e.eval)
vec = np.zeros(n_dofs)
for idof in range(n_dofs):
    G[idof] = eval_my_fun(idof, vec, f, f_xyz)
But since I’ve noticed that there is difference with the assemble function dolfin/dolfinx with RT element, I have some doubts about my way of doing this…
Why do you want to do this?
Isn’t this exactly what integrating against a test-function would give you?
If not, please elaborate why?
I want to build a Biot&Savart operator, according to:
where
  • i is the indice of the magnetic sensor
  • wf_j is the jth face shape function RT (dof_j= 1, other =0)
So how would this not be stacking for each i the assembly with a TestFunction? As that would give you a vector with all the contributions were the jth entry of the vector correponds to the contribution of the jth basis function?
Sorry, I have difficulties to understand your last reply… Could you show me a code snippet of what you are explaining ? thank you so much for your time
Say you want to assemble
L_i=\int_{\Omega} \phi_i(x)\cdot u~\mathrm{d}x
where u is some known vector function.
Then this is exactly what
V = dolfinx.fem.functionspace(mesh, ("RT", 1))
u = dolfinx.fem.Constant(mesh, ((1.0, -3.0)))
L = ufl.inner(u, v) * ufl.dx
b = dolfinx.fem.assemble_vector(dolfinx.fem.form(L))
print(b.array)
Does.
Then for you example, you would vary u for for each r_i to get your matrix operator.
