Assembling an identity matrix in Mixed spaces
FEniCS version: 2019.1.0 installed via Conda
Consider the following MWE on mixed spaces:
mesh = UnitSquareMesh(1,1)
P1 = FiniteElement('CG', triangle, 1)
P0 = FiniteElement('DG', triangle, 0)
element = MixedElement([P1, P0])
v1, v2 = TestFunctions(V)
u1, u2 = TrialFunctions(V)
# Identity matrix of size dim(P0) x dim(P0) assembled at a particular location in the global matrix
cell = Cell(mesh, 0)
Eq = assemble((1/cell.volume())*u2*v2*dx)
print(Eq.array())
Output:
[[0. 0. 0. 0. 0. 0.]
 [0. 0. 0. 0. 0. 0.]
 [0. 0. 0. 0. 0. 0.]
 [0. 0. 0. 1. 0. 0.]
 [0. 0. 0. 0. 0. 0.]
 [0. 0. 0. 0. 0. 1.]]
The above MWE successfully assembles an Identity matrix of dimension dim(\mathbb{P}_0) \times dim(\mathbb{P}_0) at the correct global positions.
Question: Is there a way to extend it to \mathbb{P}_1 finite element case?
One approach is discussed here https://fenicsproject.org/qa/5372/assemble-an-identity-matrix/,
mesh = UnitSquareMesh(10, 10)
form = inner(u, v)*dx
I = assemble(form)
I.zero()
I.set_diagonal(interpolate(Constant(1), V).vector())
However I can not add the obtained matrix I to a variational form. Is there a way to do this before assembling it?
Hi, a diagonal mass matrix can be obtained with P1 element by changing the integration rule of the measure to a “vertex” scheme, see here:
https://comet-fenics.readthedocs.io/en/latest/demo/tips_and_tricks/mass_lumping.html#Second-method
However, please note that you will not necessarily end up with an identity matrix, depending on the number of elements sharing a common dof.
