Assembly of a row matrix for an integral constraint
Dear users,
I found a performance issue when assembling a row matrix A of global size (1, N). These kind of matrices arise naturally when imposing a global constraint for singular problems, see for instance, Real function spaces — scifem
As it is currently implemented, the assembly of the row matrix for real spaces is carried out in a single core and then distributed. It would be much faster to assemble the transpose matrix A^T of global size (N, 1) and then transpose it.
First I would like to share a minimal example that reproduces the performance issue (see below). Then, I would like to ask you for help in order to create and assemble the transpose (A^T)^T .
I have tried with A_T_T = PETSc.Mat().createTranspose(A_T)[1] but it seems this is not compatible with a following Mat.NEST and LU solver, I get kspConvergedReason = -11 or OUT of Memory. Any idea? [2]
import dolfinx.fem.petsc
from scifem import create_real_functionspace
from timeit import default_timer as timer
comm = MPI.COMM_WORLD
rank = comm.rank
size = comm.size
M_DG = 150
mesh_DG = dolfinx.mesh.create_unit_square(MPI.COMM_WORLD, M_DG, M_DG, dolfinx.mesh.CellType.triangle, dtype=np.float64)
num_cells = mesh_DG.topology.index_map(mesh_DG.topology.dim).size_global
def assemble_a10(R, V):
    W = ufl.MixedFunctionSpace(V, R)
    u, lmbda = ufl.TrialFunctions(W)
    du, dl = ufl.TestFunctions(W)
    a10 = ufl.inner(u, dl) * ufl.dx
    A_10 = dolfinx.fem.petsc.assemble_matrix(dolfinx.fem.form(a10))
    A_10.assemble()
    return A_10
def assemble_a10_transpose(R, V):
    # Assemble transpose: inner
    a01 = ufl.inner(lmbda, du) * ufl.dx
    A_01 = dolfinx.fem.petsc.assemble_matrix(dolfinx.fem.form(a01))
    A_01.assemble()
    A_10 = PETSc.Mat().createTranspose(A_01)   # MATTRANSPOSEVIRTUAL
    return A_10
V_DG = dolfinx.fem.functionspace(mesh_DG, ("DG", 1))
R_DG = create_real_functionspace(mesh_DG)
num_dofs_global_DG = V_DG.dofmap.index_map.size_global * V_DG.dofmap.index_map_bs
if MPI.COMM_WORLD.rank ==0:
    print(f"Number of dofs global for DG: {num_dofs_global_DG}")
# Allreduce to get min/max/avg times across all ranks
if rank == 0:
    print("\n--- Load balance statistics ---")
comm.Barrier()
t0 = timer()
A_DG = assemble_a10(R_DG, V_DG)
comm.Barrier()
t1 = timer()
local_time = t1 - t0
# Gather statistics across ranks
times = comm.allgather(local_time)
times_min = min(times)
times_max = max(times)
times_avg = sum(times) / len(times)
if rank == 0:
    print(f"DG: min={times_min:.6f}s, max={times_max:.6f}s, avg={times_avg:.6f}s, imbalance={(times_max/times_min - 1)*100:.1f}%")
comm.Barrier()
t0 = timer()
A_DG_T_T = assemble_a10_transpose(R_DG, V_DG)
comm.Barrier()
t1 = timer()
if rank == 0:
    print(f"DG transpose: min={times_min:.6f}s, max={times_max:.6f}s, avg={times_avg:.6f}s, imbalance={(times_max/times_min - 1)*100:.1f}%")
The output of the previous file with the command mpirun -np 6 python3 test_poisson.py is:
Number of dofs global for DG: 135000
DG: min=0.960112s, max=0.960114s, avg=0.960113s, imbalance=0.0%
DG transpose: min=0.010416s, max=0.010417s, avg=0.010417s, imbalance=0.0%
  1. assembling (A^T)^T with A_T.transpose() is much slower, maybe we need to allocate first the matrix? ↩︎
  2. Maybe like in fem.petsc with Asub = A.getLocalSubMatrix(is0[i], is1[j]) and then filling the values? ↩︎
That is not entirely true.
The assembly is still distributed, even if I agree that PETSc favours doing the transpose assembly.
If you want to use the transpose trick, you have to explicitly copy the matrix, otherwise PETSc just uses an in memory trick to transpose the original matrix.
rank = comm.rank
size = comm.size
M_DG = 150
    A_10.assemble()
    return A_10
    A_01.assemble()
    return A_01
V_DG = dolfinx.fem.functionspace(mesh_DG, ("Lagrange", 1))
if rank == 0:
comm.Barrier()
t0 = timer()
comm.Barrier()
t1 = timer()
if rank == 0:
comm.Barrier()
t0 = timer()
A_01 = assemble_a10_transpose(R_DG, V_DG)
A_10 = A_01.copy()
A_10.transpose()
comm.Barrier()
t1 = timer()
if rank == 0:
A00 = dolfinx.fem.petsc.assemble_matrix(dolfinx.fem.form(ufl.inner(ufl.grad(ufl.TrialFunction(V_DG)), ufl.grad(ufl.TestFunction(V_DG))) * ufl.dx))
A00.assemble()
A_block = PETSc.Mat().createNest([[A00, A_01], [A_10, None]])  # type: ignore
x = ufl.SpatialCoordinate(mesh_DG)
u_ex = ufl.cos(2*ufl.pi * x[0]) * ufl.cos(ufl.pi * x[1])
f = -ufl.div(ufl.grad(u_ex))
W = ufl.MixedFunctionSpace(V_DG, R_DG)
v, q = ufl.TestFunctions(W)
L = ufl.inner(f, v) * ufl.dx + ufl.inner(dolfinx.fem.Constant(mesh_DG, PETSc.ScalarType(0.0)), q) * ufl.dx
b = dolfinx.fem.petsc.assemble_vector(dolfinx.fem.form(ufl.extract_blocks(L)), kind="nest")
for b_sub in b.getNestSubVecs():
    b_sub.ghostUpdate(addv=PETSc.InsertMode.ADD, mode=PETSc.ScatterMode.REVERSE)
    b_sub.ghostUpdate(addv=PETSc.InsertMode.INSERT, mode=PETSc.ScatterMode.FORWARD)
ksp = PETSc.KSP().create(comm)
ksp.setOperators(A_block)
ksp.setType("preonly")
pc = ksp.getPC()
pc.setType("lu")
ksp.setErrorIfNotConverged(True)
xh = b.copy()
ksp.solve(b, xh)
u, lmbda = dolfinx.fem.Function(V_DG), dolfinx.fem.Function(R_DG)
dolfinx.fem.petsc.assign(xh, [u, lmbda])
u.x.scatter_forward()
error = dolfinx.fem.assemble_scalar(dolfinx.fem.form(ufl.inner(u - u_ex, u - u_ex) * ufl.dx))
error = np.sqrt(comm.allreduce(error, op=MPI.SUM))
if rank == 0:
    print(f"Error: {error}")
yields:
root@docker-desktop:~/shared/scifem# mpirun -n 4 python3 mwe_rs.py
Number of dofs global for DG: 22801
DG: min=0.029240s, max=0.029240s, avg=0.029240s, imbalance=0.0%
DG transpose: min=0.008623s, max=0.008623s, avg=0.008623s, imbalance=0.0%
Error: 0.0001414841063168248
