I apologize in advance that I won’t be able to include an example reproducible code at the moment, but I will try to explain the problem as much as I could and hopefully I could get some clues on how to debug my problem.
I am currently running a 2D simulation of a large mesh (generated by Gmsh) of ~30000 nodes, of which specific nodes (~4000 nodes) on the boundaries and inside the domain are to be assigned a zero Dirichlet BC. I obtained a list of these nodes from Gmsh and if I directly plot these nodes on top of the mesh on any visualization software they match fine. However, when the list is passed to fenics to solve the problem, many of the nodes fail to get assigned with the BCs. Following is an example code of how I incorporate the list of nodes into fenics:
BC_nodes = np.loadtxt('list.txt',delimiter=',')
def specified_nodes(x, on_boundary):
Status = False
for i in range(BC_nodes.shape[0]):
Status = near(x[0], BC_nodes[i,0]) and near(x[1], BC_nodes[i,1] )
if Status:
break
return Status
The .txt
file contains coordinates of all the specified nodes, the first column contains the x coordinates and the second column contains the y coordinates. The above function is being passed to Dirichlet BC with this:
bcs = DirichletBC(V, Constant(0.0), specified_nodes)
More information on this code, I use Newton solver:
solver = NewtonSolver()
solver.parameters["linear_solver"] = "mumps"
solver.parameters["convergence_criterion"] = "incremental"
solver.parameters["relative_tolerance"] = 1e-6
solver.parameters["report"] = False
And assemble the nonlinear problem with the class:
class PDEEquation(NonlinearProblem):
def __init__(self, L, a, bcs):
self.L = L
self.a = a
self.bcs = bcs
def F(self, b, x):
assemble(self.L, tensor=b)
self.bcs.apply(b,x)
def J(self, A, x):
assemble(self.a, tensor=A)
self.bcs.apply(A)
Furthermore, the mesh generated by Gmsh is saved in .msh
format and is converted to .xml
using dolfin-convert
Any insight or suggestion on where to debug is greatly appreciated, I am also thinking if there’s a more efficient way to tell fenics these specific nodes instead of looping through the whole list every time the solver is called.
Thank you!
