Currently, I am solving a nonlinear problem with a large network mesh.
I need to set DirichletBC values to 5000+ terminal points of the network.
I am using a for loop to assign the values now, a brief example is shown below:
bcs = [ ]
for p in range(0,4000):
BCvalue = value_table[p] # value_table is a np.array of the terminal points value
def u0_boundary(x, on_boundary):
tol = 1e-14
return on_boundary and abs(term_nodes_coord[p][0]-x[0] ) < tol # term_nodes_coord is the coordinates of terminal points in [ x, y, z]
bc_set = DirichletBC(V, BCvalue, u0_boundary)
bcs.append(bc_set)
I believe the for-loop process really slows down the solver’s speed. Is there any way I can set all BCs faster? I know the indices and coordinates of all the terminal points. Can I mark all terminal points and only call DirichletBC() once?
Many thanks for the help!
