Hi everyone,
I currently have some code where I am trying to find the maximum and minimum value of a function on the mesh after a certain amount of time and output these values to a txt file, the greatly simplified code is shown below:
mesh = UnitSquareMesh(10,10)
space = FunctionSpace(mesh, ‘P’, 1)
T = project(Expression(“10x[0]+100x[1]”, degree=2), Space)
max_T = max(T.vector())
print(“T_max is:”, max_T)
with open(“test.txt”, ‘a’) as f:
f.write(str(max_T))
In my full code, because the system I am modelling is complex, I run this system in parallel via mpirun -n 10 python3 code.py. However, when this finishes, I obtain something like this in my terminal:
T_max is: 1508.040424
T_max is: 1501.694996
T_max is: 1553.542122
And all of these max values are output to my txt file where I only wanted the maximum to be sent to the txt file. Is there a way for a loop to be constructed over all different parallel runs in order for the ‘true’ max value to be selected and output to the txt file?
Thanks in advance
