Average value of solution across boundary of mesh
Hi everyone,
I am currently trying to find the average value of my solution Temp across the surface of my 2D mesh. But I am unsure how I can accomplish this.
Here is the example I have so far:
from ufl import as_tensor
from ufl import Index
import math
from scipy.optimize import curve_fit
mesh = UnitCubeMesh(16,16,16)
Space = FunctionSpace(mesh, ā€˜P’, 1)
Temp = project(Expression(ā€œ10*x[0]+100*x[1]+ x[2]ā€, degree=3), Space)
class marker(SubDomain):
        return near(x[2], 1) and on_boundary
Is there an inbuilt function that I can use this to find the average of Temp across the face of my mesh at the given boundary?
How about creating a MeshFunction based on your marker,say tag all facets to integrate over with 1, and do the following:
mf = dolfin.MeshFunction("size_t", mesh, mesh.topology().dim()-1)
marker().mark(mf, 1)
ds1 = dolfin.Measure("ds", domain=mesh, subdomain_data=mf, subdomain_id=1)
print(assemble(T*ds1)/assemble(1*ds1))
How is this done using Dolfinx?
See for instance https://jsdokken.com/dolfinx-tutorial/chapter3/robin_neumann_dirichlet.html: search for the word meshtags (which replaced dolfin.MeshFunction) and assemble_scalar (which replace dolfin.assemble)
