Hello dolfinx users,
I want to compute the surface average of a normalised scalar product \frac{1}{S}\int\frac{\left|\left<u,v\right>\right|}{\left||u\right||\left||v\right||}dS over a region of the mesh in dolfinx
. I’m doing something wrong though, because I’m always getting something larger than one.
import dolfinx as dfx
from mpi4py.MPI import COMM_WORLD as comm
# Shortforms
n=10
mesh = dfx.mesh.create_unit_square(comm, n, n)
def save(name,f):
with dfx.io.XDMFFile(comm, name+".xdmf", "w") as xdmf:
xdmf.write_mesh(mesh)
xdmf.write_function(f)
# Create vectors (placeholder)
FS_v = dfx.fem.FunctionSpace(mesh,ufl.VectorElement("CG",mesh.ufl_cell(),2))
v1, v2 = dfx.fem.Function(FS_v), dfx.fem.Function(FS_v)
v1.interpolate(lambda x: x.reshape(2,-1))
def v2_f(x):
x[1,:]=x[0,:]-x[1,:]
return x.reshape(2,-1)
v2.interpolate(v2_f)
save("v1",v1)
save("v2",v2)
# Integration area (triangle)
x0,x1,x2=(0,.5),(1,1),(1,0)
def line(x,x1,x2): return x[1]<(x2[1]-x1[1])*(x[0]-x1[0])/(x2[0]-x1[0])+x1[1]
def kernel(x):
res = np.zeros_like(x[0])
res[line(x,x0,x1)]=1
res[line(x,x0,x2)]=0
return res
FS_e = dfx.fem.FunctionSpace(mesh,ufl.FiniteElement("CG",mesh.ufl_cell(),2))
k = dfx.fem.Function(FS_e)
k.interpolate(kernel)
s=dfx.fem.assemble_scalar(dfx.fem.form(k*ufl.dx)).real # Scaling factor for weighting surface
if s==0: s=1 # If the kernel has no support over this proc, don't do anything
def dot(u,v=None):
if v is None: v=u
return ufl.real(ufl.dot(u,v))
# Compute dot product and orientation
ae,re = dfx.fem.Function(FS_e),dfx.fem.Function(FS_e)
ae.interpolate(dfx.fem.Expression(ufl.sqrt(dot(v1,v2)**2)*k,FS_e.element.interpolation_points()))
ae.x.array[:]=np.positive(np.nan_to_num(ae.x.array[:])/s)
ae.x.scatter_forward()
save("pdt",ae)
re.interpolate(dfx.fem.Expression(ae/ufl.sqrt(dot(v1))/ufl.sqrt(dot(v2)),FS_e.element.interpolation_points()))
re.x.array[:]=np.nan_to_num(re.x.array[:])
re.x.scatter_forward()
save("alignement",re)
# Compute and communicate integrals
ae,re=dfx.fem.assemble_scalar(dfx.fem.form(ae*ufl.dx)).real,dfx.fem.assemble_scalar(dfx.fem.form(re*ufl.dx)).real
ae,re=comm.gather(ae),comm.gather(re)
if comm.rank==0:
ae,re = sum(ae), sum(re)
print("a=",ae,"re=",re,flush=True)
Even though everything here is real, my use case would be simpler if I could run it in complex mode. Right now I get the wrong result re\approx7 indifferently in real of complex. My use case is also parallel (I ran this on 8 procs).
