Axisymmetric problems: Nearly incompressible linear viscoelastic solid sphere with surface tension
Deal all,
I am currently trying to implement a nearly incompressible linear viscoelastic solid sphere with surface tension.
The viscoelastic part is running ok but introducing surface tension is creating problems, as the stress is higher at the top node and leads to wrong or diverging results.
The code is quite long, but the solver uses:
############################### VISCOELASTIC RESIDUAL ################################
    dx = ufl.Measure("dx",domain=domain,metadata={"quadrature_degree": deg_quad, "quadrature_scheme": "default"})
    Residual_viscoelastic = ufl.dot(eps_Mandel_axi(u_,r), sig) *2*np.pi*r* dx
    viscoelastic_tangent_form = ufl.dot(eps_Mandel_axi(v,r), ufl.dot(Ct, eps_Mandel_axi(u_,r))) *2*np.pi*r*dx
for viscoelasticity (I am using this tutorial for viscoelasticity).
Surface tension and later the solver write:
################################## SURFACE TENSION RESIDUAL #######################
    # Surface tension coefficient
    sigma = fem.Constant(domain, surface_tension_value)
    # Deformation gradient
    F = ufl.Identity(2) + ufl.grad(u)
    # Reference normal to the boundary
    n = ufl.FacetNormal(domain)
    t_ref = ufl.as_vector([-n[1], n[0]])   # unit tangent, since n is unit
    # actual meridian stretch ratio (current length / reference length)
    Ft = ufl.dot(F, t_ref)
    J_surf = ufl.sqrt(ufl.dot(Ft, Ft))
    # Current configuration: both radius and arc length change
    r_current = r + u[0]  # Current radius
    Surface_tension_energy = sigma * 2 * np.pi  * r_current * J_surf * ds(1)
    # Residual and tangent from surface tension
    Residual_surface_tension = ufl.derivative(Surface_tension_energy, u, u_)
    surface_tension_tangent_form = ufl.derivative(Residual_surface_tension, u, v)
The solver reads:
###################### PROBLEM AND RESOLUTION ############################
    tangent_problem = CustomLinearProblem(
        tangent_form,
        -Residual,
        u=du,
        bcs=bcs,
        petsc_options={
            "ksp_type": "preonly",
            "pc_type": "lu",
            "ksp_monitor": None,          # print linear residuals per iteration
            #"ksp_view": None,             # print KSP solver info
            #"ksp_converged_reason": None  # why linear solver converged or failed
        petsc_options_prefix="tangent_"
    newton = CustomNewtonSolver(tangent_problem)
    newton.callback = constitutive_update
with boundary conditions classical for axisymmetry.
A specific image summarizing the problem would be this one, at the beginning of the simulation:
Would you have any idea what to look for please ?
Note: the \theta\theta Mandel strain contribution is very slightly regularized to avoid divergence at r=0.
Have you tried solving for a problem that is only radially dependent? I.e., some purely ‘r’ dependent forcing/BC ? To try and isolate when the erroneous stress concentration kicks in.
P.s., I wonder if you’re actually solving an axisymmetric problem. You’re correctly modifying the integration measure into 2 * pi * r * dx, but I’d suppose the derivative operators on vectors and tensorts require more care (e.g., gradient of u), don’t they?
