I’ve been messing around all day to get the docker image of dolfinx_mpc:v0.10.0 to work but so far without luck.
Currently my Dockerfile is:
FROM ghcr.io/jorgensd/dolfinx_mpc:v0.10.0
#FROM dolfinx/dev-env:v0.10.0
# Install curl and ca-certificates
RUN apt-get update && apt-get install -y --no-install-recommends curl ca-certificates
# Download and install UV
ADD https://astral.sh/uv/install.sh /uv-installer.sh
RUN sh /uv-installer.sh && rm /uv-installer.sh
ENV PATH="/root/.local/bin/:$PATH"
# Install GraphViz
RUN apt-get install graphviz
# Set working directory
WORKDIR /workspace
# Copy project metadata
COPY pyproject.toml .
COPY uv.lock .
# Install packages in virtual environment
ENV UV_ENV="/dolfinx-env"
ENV UV_NO_VENV=1
RUN uv sync --all-extras --active
Whenever I try to run any simple code which uses dolfinx, I run into the issue that basix, ufl, and ffcx are not installed on the container. Installing them via UV (or pip) creates new issues and I’m fairly sure this is not needed.
Could anyone shed some light on what I am doing wrong?
import dolfinx.fem
File "<stdin>", line 1, in <module>
File "/usr/local/dolfinx-real/lib/python3.12/dist-packages/dolfinx/__init__.py", line 32, in <module>
from dolfinx import fem, geometry, graph, io, jit, la, log, mesh, nls, plot
File "/usr/local/dolfinx-real/lib/python3.12/dist-packages/dolfinx/fem/__init__.py", line 23, in <module>
from dolfinx.fem.assemble import (
File "/usr/local/dolfinx-real/lib/python3.12/dist-packages/dolfinx/fem/assemble.py", line 24, in <module>
from dolfinx.fem.bcs import DirichletBC
File "/usr/local/dolfinx-real/lib/python3.12/dist-packages/dolfinx/fem/bcs.py", line 20, in <module>
from dolfinx.fem.function import Constant, Function, FunctionSpace
File "/usr/local/dolfinx-real/lib/python3.12/dist-packages/dolfinx/fem/function.py", line 18, in <module>
import basix
ModuleNotFoundError: No module named 'basix'
