Bessel function and complex number
It took me quite a while to understand why one of my code was not working. I managed to find the source of the issue. It is quite unclear to me if the issue comes from ufl or the use of create_real_functionspace but it seems that bessel function can not be used with complex argument. Here is a MWE:
from scifem import create_real_functionspace
from scipy.special import jv as jv_scipy
msh = dolfinx.mesh.create_rectangle(comm=MPI.COMM_WORLD, points=((0., 0.), (1., 1.)), n=(1, 1), cell_type=dolfinx.mesh.CellType.triangle)
R = create_real_functionspace(msh)
x = dolfinx.fem.Function(R)
f = dolfinx.fem.Function(R)
x_value = 12.0j
x.x.array[:] = x_value
x.x.scatter_forward()
def my_function(x):
    jv = ufl.bessel_J if isinstance(x, ufl.core.expr.Expr) else jv_scipy
    return jv(0, x)
f.interpolate(dolfinx.fem.Expression(my_function(x), R.element.interpolation_points))
print(f.x.array[:],' / ',my_function(x_value)) # [1.+0.j]  /  (18948.925349296307+0j)
We see that the value is not the same as the one returned by the scipy implementation of the Bessel function.
I’m quite unsure whether I should post that to the ufl issue tracker, let me know if that is the case.
Unfortunately, it looks like the standard C library does not have an implementation of bessel functions of the first kind for complex arguments: IBM Documentation
You can try this with something like
#include <stdio.h>
#include <math.h>
#include <complex.h>
int main() {
    double complex x = 12.0*I;
    int n = 0;
    double complex result = jn(n, x);
    printf("J%d(%.1f + %.1fi) = %.1f + %.1fi\n", n, x, result);
    return 0;
Which gives me
J0(0.0 + 12.0i) = 1.0 + 0.0i
One workaround may be to use GitHub - a-latyshev/dolfinx-external-operator: Extension of DOLFINx implementing the concept of external operator · GitHub and have it point to the scipy implementation for complex numbers.
Thank you for this solution, it looks like it could solve my problem.
To conclude this post, here is an example using External operator, and comparing it to assigning data directly to a DG-0 function:
import basix.ufl
from dolfinx_external_operator import (
    FEMExternalOperator,
    evaluate_external_operators,
    replace_external_operators,
    evaluate_operands,
def g_impl(uuh):
    """Identity operator"""
    output = jv_scipy(0, uuh)
    return output.reshape(-1)
def g_external(derivatives):
    if derivatives == (0,):  # no derivation, the function itself
        return g_impl
        return NotImplementedError
mesh = dolfinx.mesh.create_unit_square(MPI.COMM_WORLD, 5, 5)
quadrature_degree = 1
Qe = basix.ufl.quadrature_element(mesh.basix_cell(), degree=quadrature_degree, value_shape=())
Q = dolfinx.fem.functionspace(mesh, Qe)
coefficient = dolfinx.fem.Function(Q, dtype=np.complex128)
x_value = np.complex128(12.0j)
x = dolfinx.fem.Constant(
    mesh,
    x_value,
f = FEMExternalOperator(x, function_space=Q, external_function=g_external, coefficient=coefficient)
dx = ufl.Measure("dx", domain=mesh)
Q = dolfinx.fem.functionspace(mesh, ("DG", 0))
g = dolfinx.fem.Function(Q, dtype=np.complex128)
g.x.array[:] = g_impl(x_value)
a = (f - g) * ufl.conj(f - g) * dx
a_replaced, a_external_operators = replace_external_operators(a)
# Pack coefficients for g
evaluated_operands = evaluate_operands(a_external_operators)
evaluate_external_operators(a_external_operators, evaluated_operands)
error = dolfinx.fem.assemble_scalar(dolfinx.fem.form(a_replaced, dtype=np.complex128))
print("Error:", np.sqrt(error))
output
Error: 0j
