Yes , it work successfully and just like what I want. Thank you for your help.
And I still need your help.Here are my problem:
- About the boundary defined. When I build boundary without u(y = 0) = 0, the solution was a little different at y = 1 , but totally different at y = 0 , especially the real part. The figure are as follow, first one is without u(y = 0) = 0. The second one is with u(y = 0 ) = 0.The black parts are just because my grid is too dense.
the real part of the numerical solution without u(y = 0) = 0
the imaginary part of the numerical solution without u(y = 0) = 0
the real part of the numerical solution with u(y = 0) = 0
the imaginary part of the numerical solution with u(y = 0) = 0
The difference confuse me. I want you to tell me why. The main code is as follow:
import math
from dolfinx import fem, mesh, plot
from ufl import ds, dx, grad, inner, sin
msh = mesh.create_rectangle(comm=MPI.COMM_WORLD,
points=((0.0, 0.0), (3.0, 1.0)), n=(300, 100),
cell_type=mesh.CellType.triangle,)
V = fem.FunctionSpace(msh, ("Lagrange", 1))
facets = mesh.locate_entities_boundary(msh, dim=1,
marker=lambda x: np.logical_or(np.isclose(x[0], 0.0),
np.isclose(x[0], 3.0))) # without u(y = 0) = 0
# facets = mesh.locate_entities_boundary(msh, dim=1,
# marker=lambda x: np.logical_or(np.logical_or(np.isclose(x[0], 0.0),
# np.isclose(x[0], 3.0)),
# np.isclose(x[1], 0.0))) # with u(y = 0) = 0
dofs = fem.locate_dofs_topological(V=V, entity_dim=1, entities=facets)
bc = fem.dirichletbc(value=ScalarType(0), dofs=dofs, V=V)
u = ufl.TrialFunction(V)
pi = math.pi
x1 = sin(pi * x[0])
y1 = sin(2 * pi * x[1])
f = pi * x1 * (2.5 * y1 + 1j * pi * x[1])
g = (1 + 1j) * sin(pi * x[0])
L = inner(f, v) * dx + inner(g, v) * ds
problem = fem.petsc.LinearProblem(a, L, bcs=[bc], petsc_options={"ksp_type": "preonly", "pc_type": "lu"})
uh = problem.solve()
And the pyvista part
# uh.real
try:
import pyvista
cells, types, x = plot.create_vtk_mesh(V)
grid = pyvista.UnstructuredGrid(cells, types, x)
grid.point_data["ur"] = uh.x.array.real
grid.set_active_scalars("ur")
plotter = pyvista.Plotter()
warped = grid.warp_by_scalar()
plotter.add_mesh(warped)
plotter.show_grid()
plotter.show()
except ModuleNotFoundError:
print("'pyvista' is required to visualise the solution")
print("Install 'pyvista' with pip: 'python3 -m pip install pyvista'")
# uh.imag
try:
import pyvista
grid.point_data["ui"] = uh.x.array.imag
grid.set_active_scalars("ui")
plotter.show_grid()
plotter.show()
2.About my recent and initial problem----the answer of “uh * ds”
The answer should be j * 2 / pi , approximately equal to j * 0.636619772
Only with the boundary condition u(y = 0) = 0, I could get
(-2.3239149089002746e-05+0.6365176098632956j)
It’s very close to the analytical solution. That’s sounds a good news for me.
By the way, I want to know how to type formula in the topic and reply.
