I found a strange behavior with N1[E/F] elements. With specific mesh the norm of any assembled matrix defined on it will blowup. This happen with every form I tried to assemble and I could not trace more precisely the root of the problem.
A slight deformation to the mesh fix this however this is still problematic for convergence analysis.
Here a MWE :
import mshr as mshr
Elemf1 = FiniteElement('P-', cell='tetrahedron', degree=1, form_degree=1)
boxt = mshr.Box(mshr.dolfin.Point(-0.5,-0.00,-0.75), mshr.dolfin.Point(0.5,1.,0.25))
mesh = mshr.generate_mesh(boxt,24)
W = FunctionSpace(mesh, Elemf1)
u = TrialFunction(W)
v = TestFunction(W)
A = assemble(inner(u,v)*dx)
print(A.norm('l1')) # return 18337210665087.703
boxt2 = mshr.Box(mshr.dolfin.Point(-0.501,-0.00,-0.75), mshr.dolfin.Point(0.5,1.,0.25))
mesh2 = mshr.generate_mesh(boxt2,24)
W2 = FunctionSpace(mesh2, Elemf1)
u2 = TrialFunction(W2)
v2 = TestFunction(W2)
A2 = assemble(inner(u2,v2)*dx)
print(A2.norm('l1')) # return 1.0328415765439531
I use the version 2019.1.0 within a docker.
No error are reported (however the solving obviously fail to find any meaningful solution).
