I have a problem picking the correct indices on a mesh.
I’m using an external tool for picking a face on a mesh with corresponding indices and then I import that list of indices to Fenics, hoping to use the list for applying boundary condition on those points.
As I’ve understood Fenics forces UFC-ordering of the mesh and I suspect that has something to do with it. I’ve looked in to the dofmapping, but I seem to not understand it fully.
This is my code for picking the bound indices and below you can see a picture of the result.
def _DirichletBC_On_Vertices(mesh, V, condition):
bc = []
for vertex in vertices(mesh):
if vertex.global_index() in bound_idxs:
point = vertex.point().array()
bc.append(
DirichletBC(
V,
condition,
"near(x[0],"
+ str(vertex.point().x())
+ ") && near(x[1],"
+ str(vertex.point().y())
+ ") && near(x[2],"
+ str(vertex.point().z())
method="pointwise",
return bc
In the external tool I’ve placed a boundary in the middle of each flat surface of the bolt, but the results seem almost random. Any thoughts?
