Boundary condition Expression gives error on Apply
The error is at the botom: it only happens when I apply a veloicty dirichlet BC not a pressure dirichlet.
bcp.append(DirichletBC(Q,Constant(0.0) ,boundaries,inflow_vein))
bcp.append(DirichletBC(V,Constant(0.0) ,boundaries,inflow_vein))
The one in V, velocity space gives error, in Q , pressure space, doesnt.
File "/home/jack/anaconda2/envs/fenicsproject/lib/python3.7/site-packages/oasis-2018.1-py3.7.egg/oasis/problems/NSfracStep/Test_case.py", line 248, in initialize
    [bc.apply(x_1[ui]) for bc in bcs[ui]]
  File "/home/jack/anaconda2/envs/fenicsproject/lib/python3.7/site-packages/oasis-2018.1-py3.7.egg/oasis/problems/NSfracStep/Test_case.py", line 248, in <listcomp>
RuntimeError:
*** Error:   Unable to successfully call PETSc function 'VecSetValuesLocal'.
*** Reason:  PETSc error code is: 63 (Argument out of range).
*** Where:   This error was encountered inside /home/conda/feedstock_root/build_artifacts/fenics-pkgs_1569407024839/work/dolfin/dolfin/la/PETScVector.cpp.
*** Process: 0
*** DOLFIN version: 2019.1.0
*** Git changeset:  f3de96341c54e434c48115de5a3975b482aee933
anyone any ideas?
As you have not provided a minimal example, i have to do an educated guess. Is your FunctionSpace V a VectorFunctionSpace? If Yes, see:
