Hello everyone,
I had a constant pressure boundary condition, which I wanted to ramp up to the value instead of prescribing the value from t=0. I am using the oasis solver. So I wanted to change
bcp.append(DirichletBC(Q,Constant(270.0),boundaries,inflow_vein))
to
pres_inflow_expres = Expression((‘dt * pmax’),
degree = 1 , dt = dt , pmax = pmax )
bcp.append(DirichletBC(Q,pres_inflow_expres,boundaries,inflow_graft))
This is the total piece of code that doesnt seem to work now
def create_bcs(V, Q,pmax, NS_parameters, **NS_namespace):
“”“Function to define the boundary conditions”“”pres_inflow_expres = Expression(('dt * pmax'),\ degree = 1 , dt = dt , pmax = pmax ) #pressure_waveform = Expression() # Specify empty bcs for the velocity components and the pressure bcu_x = [] bcu_y = [] bcu_z = [] bcp = [] # Define the boundary conditions for the pressure and the individual # velocity components vel_x_wall = Constant(0.0) vel_y_wall = Constant(0.0) vel_z_wall = Constant(0.0) bcu_x.append(DirichletBC(V, vel_x_wall, boundaries, walls)) bcu_y.append(DirichletBC(V, vel_y_wall, boundaries, walls)) bcu_z.append(DirichletBC(V, vel_z_wall, boundaries, walls)) bcu_x.append(DirichletBC(V, Constant(0.0), boundaries, inflow_vein)) #deze normaal uitzetten bcu_y.append(DirichletBC(V, Constant(0.0), boundaries, inflow_vein)) #deze normaal uitzetten bcu_z.append(DirichletBC(V, Constant(0.0), boundaries, inflow_vein)) #deze normaal uitzetten #bcp.append(DirichletBC(Q,pres_inflow_expres,boundaries,inflow_graft)) #bcp.append(DirichletBC(Q,Constant(183.0),boundaries,inflow_vein)) #DEZE normaal aanzetten #bcp.append(DirichletBC(Q,Constant(0.0),boundaries,outflow)) deze stond aan bcp_out = (DirichletBC(Q,Constant(0.0),boundaries,outflow)) bcp_graft = (DirichletBC(Q,pres_inflow_expres,boundaries,inflow_graft)) ###### ###### wellicht alle bcp apart aan p= dictionary toevoegen ipv in een bcp lijst bcs =dict( u0=bcu_x, u1=bcu_y, u2=bcu_z, p=[bcp_out,bcp_graft] ) # Return the boundary conditions return bcs, dict(ife = [pres_inflow_expres])def initialize(p_1,x_1, x_2, bcs, v, q_, **NS_namespace):
for ui in x_1:
[bc.apply(x_1[ui]) for bc in bcs[ui]]
for ui in x_2:
[bc.apply(x_2[ui]) for bc in bcs[ui]]
this now gives the error:
1. SETUP PATHS--------------------------------------------------------------------------------e[0m
e[1;37;34mReading input from: /home/jack/oasis/VenAn_simulation/input/Meshes_p1/followup1_melem_03.xdmf
Saving output to: /home/jack/oasis/output_3D_followup1_2_ramp_tot_270
e[1;37;34mREADING MESH e[0m
e[1;37;34m DONE
e[1;37;34mREADING MARKERS e[0m
e[1;37;31mCreating initial folderse[0m
File “NSfracStep.py”, line 137, in
initialize(**vars())
File “/home/jack/anaconda2/envs/fenicsproject/lib/python3.7/site-packages/oasis-2018.1-py3.7.egg/oasis/problems/NSfracStep/PaSpec3D.py”, line 194, in initialize
TypeError: tuple indices must be integers or slices, not str
I’m not sure what the mistake is I made.
Thanks for your help.
Cheers,
Jack
