Boundary Condition Issues in FEniCS with Discontinuous Galerkin Method
I am solving for ψ in a channel using the Discontinuous Galerkin (DG) method in FEniCS. While the solution satisfies boundary conditions for smaller channel heights H (around 10−6), it fails to do so at larger values (e.g., 50×27×10−6). I would appreciate any suggestions or insights into potential errors or incorrect implementations in this code. Below is a code example.
constants
H = 27*50e-6
epsilon_n = 7.0922e-10
zeta0 = 20e-3
Farad = 96485.33289
e = 1.602176634e-19
k = 1.380649e-23
T_flu = 298
c_i0 = 9.44e-5
R = 8.3145
degree = 2
parameter values
p1 = (H**2 * Farad * c_i0 * e) / (epsilon_n * k * T_flu)
a = 1
d = Constant((e * zeta0)/(k * T_flu))
mesh generation
channel_length, channel_height = 1, 1 / 27
patch_size = channel_height
channel = Rectangle(Point(0, 0), Point(channel_length, channel_height))
mesh = generate_mesh(channel, 500)
P = FunctionSpace(mesh, “DG”, degree)
Trial and test functions
psi_trial = TrialFunction(P)
psi = Function(P)
psi_test = TestFunction(P)
Penalty parameters
alpha = Constant(50.0)
alpha_2 = Constant(1000.0)
h = Constant(mesh.hmax())
Boundary Conditions
class InletBoundary(SubDomain):
return abs(x[0] - 0) < DOLFIN_EPS and on_boundary
class OutletBoundary(SubDomain):
return abs(x[0] - channel_length) < DOLFIN_EPS and on_boundary
inlet = InletBoundary()
outlet = OutletBoundary()
class DirichletBoundary_upper_left(SubDomain):
return (
between(x[0], (- 3*patch_size/2 + channel_length/2,
-patch_size/2 + channel_length/2))
and abs(x[1] - channel_height) < DOLFIN_EPS
and on_boundary
class DirichletBoundary_upper_right(SubDomain):
return (
between(x[0], (patch_size/2 + channel_length/2, 3 * patch_size/2 + channel_length/2))
and on_boundary
class DirichletBoundary_lower_left(SubDomain):
return (
and abs(x[1] - 0) < DOLFIN_EPS
and on_boundary
class DirichletBoundary_lower_right(SubDomain):
return (
and on_boundary
upper_left = DirichletBoundary_upper_left()
lower_left = DirichletBoundary_lower_left()
upper_right = DirichletBoundary_upper_right()
lower_right = DirichletBoundary_lower_right()
class DirichletBoundary_other(SubDomain):
return (
on_boundary
and not (
upper_left.inside(x, on_boundary) or
lower_left.inside(x, on_boundary) or
upper_right.inside(x, on_boundary) or
lower_right.inside(x, on_boundary) or
inlet.inside(x, on_boundary) or
outlet.inside(x, on_boundary)
other = DirichletBoundary_other()
Notations for DG SIP
dx = Measure(‘dx’, domain=mesh)
ds = Measure(‘ds’, domain=mesh) # Exterior facets
dS = Measure(‘dS’, domain=mesh) # Interior facets
boundary_markers = MeshFunction(“size_t”, mesh, mesh.topology().dim() - 1)
boundary_markers.set_all(0)
upper_left.mark(boundary_markers, 1)
upper_right.mark(boundary_markers, 1)
lower_left.mark(boundary_markers, 1)
lower_right.mark(boundary_markers, 1)
other.mark(boundary_markers, 2)
ds = Measure(“ds”, domain=mesh, subdomain_data=boundary_markers)
u_patch = Constant(d)
Solve
a_volume = inner(grad(psi_trial), grad(psi_test)) * dx + p1 * a * psi_trial * psi_test * dx
a_interior = (
- inner(avg(grad(psi_trial)), jump(psi_test, n)) * dS
+ inner(avg(grad(psi_test)), jump(psi_trial, n)) * dS
+ alpha/h * inner(jump(psi_trial, n), jump(psi_test, n)) * dS
a_boundary = (
- inner(grad(psi_trial), psi_test * n) * ds(1) - inner((psi_trial) * n, grad(psi_test)) * ds(1) + alpha_2/h * (psi_trial) * psi_test * ds(1)
- inner(grad(psi_trial), psi_test * n) * ds(2)
- inner((psi_trial) * n, grad(psi_test)) * ds(2) + alpha_2/h * (psi_trial) * psi_test * ds(2)
billinear = a_volume + a_boundary + a_interior
L = p1 * psi_test *dx - u_patch * inner(n, grad(psi_test)) * ds(1) + alpha_2/h * (u_patch) * psi_test * ds(1)
solve(billinear == L, psi)
plt.figure(figsize=(20, 10))
c = plot(psi, cmap = “hot”)
plt.colorbar(c)
plt.title(‘Solution for ψ’)
plt.xlabel(‘x’)
plt.ylabel(‘y’)
Please format your code with markdown code syntax, ie
```python
#add code here
and ensure that the code is runnable by others.
Additionally, as your mesh is a square mesh, I would advice you to start by using a built in mesh, rather than mshr, as mshr has been deprecated for many years and is not a software many people now have installed on their system.
Thank you very much for your reply. I have used a built in mesh in this code. Please find the code below :
# constants
H = 27*50e-6
zeta0 = 20e-3
Farad = 96485.33289
e = 1.602176634e-19
k = 1.380649e-23
T_flu = 298
c_i0 = 9.44e-5
R = 8.3145
degree = 2
# parameter values
a = 1
# mesh generation
mesh = RectangleMesh(Point(0, 0), Point(channel_length, channel_height), 100, 100)
P = FunctionSpace(mesh, "DG", degree)
# Trial and test functions
psi = Function(P)
# Penalty parameters
# Boundary Conditions
        return (
            and on_boundary
        return (
            and on_boundary
        return (
            and on_boundary
        return (
            and on_boundary
        return (
            on_boundary
            and not (
# Notations for DG SIP
dx = Measure('dx', domain=mesh)
ds = Measure('ds', domain=mesh)                                # Exterior facets
dS = Measure('dS', domain=mesh)                                # Interior facets
boundary_markers = MeshFunction("size_t", mesh, mesh.topology().dim() - 1)
ds = Measure("ds", domain=mesh, subdomain_data=boundary_markers)
# Solve
a_interior = (
a_boundary = (
    - inner(grad(psi_trial), psi_test * n) * ds(1) - inner((psi_trial) * n, grad(psi_test)) * ds(1) + alpha_2/h * (psi_trial) * psi_test * ds(1) \
    - inner(grad(psi_trial), psi_test * n) * ds(2) \
c = plot(psi, cmap = "hot")
plt.colorbar(c)
plt.title('Solution for ψ')
plt.xlabel('x')
plt.ylabel('y')
