Boundary conditions for coupling non-linear ODEs
Hello everyone,
I have two equations (for testing simple examples):
                                     u1'=0,
                                     u2'=0.
The boundary condition is
                                u1(0)=1, u2(0)=3
Therefore, the solution is “u1 = 1, u2 = 3”, however, we use the “NewtonSolver”, although the program runs, the results are wrong. (When only one equation or “u1(0) = u2(0)”, the result is correct). Could someone please let me know what I am doing wrong with my code. I think maybe there’s something wrong with the boundary conditions, but I don’t know how to change them. Here is the code
# bc
def left_boundary(x):
    return np.isclose(x[0], 0.0)
def right_boundary(x):
    return np.isclose(x[0], 1.0)
tdim = msh.topology.dim
msh.topology.create_connectivity(tdim-1, tdim)
left_facets = dolfinx.mesh.locate_entities_boundary(msh, tdim-1, left_boundary)
right_facets = dolfinx.mesh.locate_entities_boundary(msh, tdim-1, right_boundary)
ME0 = ME.sub(0)
ME1 = ME.sub(1)
V0, V0_to_ME0 = ME0.collapse()
V1, V1_to_ME1 = ME1.collapse()
u0 = dolfinx.fem.Function(V0)
u0.x.array[:] = 1
dofs0 = dolfinx.fem.locate_dofs_topological((ME0, V0), msh.topology.dim - 1, left_facets)
bc0 = dolfinx.fem.dirichletbc(u0, dofs0, ME0)
u1 = dolfinx.fem.Function(V0)
u1.x.array[:] = 3
dofs1 = dolfinx.fem.locate_dofs_topological((ME1, V1), msh.topology.dim - 1, left_facets)
bc1= dolfinx.fem.dirichletbc(u1, dofs1, ME1)
and the whole code is
import os
from PIL.ImageChops import constant
from fontTools.misc.transform import Scale
try:
    if not dolfinx.has_petsc:
        print("This demo requires DOLFINx to be compiled with PETSc enabled.")
        exit(0)
except ModuleNotFoundError:
    print("This demo requires petsc4py.")
    exit(0)
from dolfinx import default_real_type
from dolfinx.fem import (functionspace,
                         dirichletbc,
                         Constant,
                         Function,
                         locate_dofs_topological,
                         locate_dofs_geometrical,
                         FunctionSpace, DirichletBC, )
from dolfinx.mesh import (create_interval,
                          locate_entities_boundary,)
from dolfinx.fem.petsc import NonlinearProblem, LinearProblem
from ufl import (SpatialCoordinate,
                 TrialFunctions,
                 TestFunctions,
                 inner,
                 grad,
                 dx,
                 sin)
from basix.ufl import element,mixed_element
import pandas as pd
#Creat mesh
msh = create_interval(
    MPI.COMM_WORLD,
    nx=100,
    points=[0, 1],
nodes = msh.geometry.x[:, 0]
P1 = element("Lagrange", msh.basix_cell(), 1, dtype=default_real_type)
P2 = element("Lagrange", msh.basix_cell(), 1, dtype=default_real_type)
ME = functionspace(msh, mixed_element([P1, P2]))
v1, v2 = ufl.TestFunctions(ME)
u = Function(ME)  # current solution
u0 = Function(ME)  # solution from previous converged step
# functions
u1, u2 = ufl.split(u)
u10, u20 = ufl.split(u0)
# Zero u
u.x.array[:] = 0.0
# Interpolate initial condition
u.sub(0).interpolate(lambda x: np.full_like(x[0], 1.0))
u.sub(1).interpolate(lambda x: np.full_like(x[0], 3.0))
u.x.scatter_forward()
x = SpatialCoordinate(msh)
#noslip = np.zeros(msh.geometry.dim, dtype=PETSc.ScalarType)  # type: ignore
#facets = locate_entities_boundary(msh, msh.topology.dim - 1, noslip_boundary)
#bc0 = dirichletbc(noslip, locate_dofs_topological(V, msh.topology.dim - 1, facets), V)
# Weak statement of the equations
F1 = u1.dx(0) * v1 * dx
F2 = u2.dx(0) * v2 * dx
F = F1 + F2
# bc
ME0 = ME.sub(0)
ME1 = ME.sub(1)
u0.x.array[:] = 1
u1.x.array[:] = 3
# Create nonlinear problem and Newton solver
problem = NonlinearProblem(F, u, bcs=[bc0, bc1])
solver.rtol = 1e-8
solver.atol = 1e-10
solver.max_it = 25
# We can customize the linear solver used inside the NewtonSolver by
# modifying the PETSc options
ksp = solver.krylov_solver
opts = PETSc.Options()  # type: ignore
sys = PETSc.Sys()  # type: ignore
# For factorisation prefer superlu_dist, then MUMPS, then default
if sys.hasExternalPackage("superlu_dist"):
    opts[f"{option_prefix}pc_factor_mat_solver_type"] = "superlu_dist"
elif sys.hasExternalPackage("mumps"):
ksp.setFromOptions()
# solver
dolfinx.log.set_log_level(dolfinx.log.LogLevel.INFO)
num_iterations, converged = solver.solve(u)
assert converged, "Solver did not converge"
msh.topology.create_connectivity(1, 0)
sorted_nodes = np.argsort(nodes)
u1_values = u.sub(0).x.array[:]
u2_values = u.sub(1).x.array[:]
rank = MPI.COMM_WORLD.rank
if rank == 0:
    x_vals = nodes[sorted_nodes]
    u1_sorted = u1_values[sorted_nodes]
    u2_sorted = u2_values[sorted_nodes]
    df = pd.DataFrame({'x': x_vals, 'u1': u1_sorted, 'u2': u2_sorted})
    df.to_csv("solution.csv", index=False)
    print("已保存为 solution.csv")
    plt.figure(figsize=(8, 5))
    plt.plot(x_vals, u1_sorted, label="u1", linewidth=2)
    plt.plot(x_vals, u2_sorted, label="u2", linewidth=2)
    plt.xlabel("x")
    plt.ylabel("Solution")
    plt.title("Solutions u1 and u2 vs x")
    plt.legend()
    plt.grid(True)
    plt.tight_layout()
    plt.savefig("solution_plot.png", dpi=300)
import sys
sys.exit(0)
This is your issue.
When you use sub(i) on a function, you only get a view into the sub-space. The underlying data array refers to u.x.array.
Changing this to:
u1_values = u.sub(0).collapse().x.array[:]
u2_values = u.sub(1).collapse().x.array[:]
resolves your issue
