Problem with coupling non linear PDE
Dear all,
I’m rather new to FeniCS and to FEM so have a hard time currently. During solving of the first problem of the non-linear model. I can not understand how you can add boundary conditions (Neuman and Dirichlet). All information on the web did not help me up to now.
I try to solve the time-dependent non-linear PDE with different boundary conditions at different domain positions (Dirichlet and Neumann).
import pygmsh
from dolfinx import log, default_scalar_type
from dolfinx.fem.petsc import NonlinearProblem, LinearProblem, assemble_matrix, create_vector, assemble_vector, apply_lifting, set_bc
from dolfinx.io import VTXWriter, XDMFFile, gmshio
from dolfinx import nls
print(f"DOLFINx version: {dolfinx.__version__} based on GIT commit: {dolfinx.git_commit_hash} of https://github.com/FEniCS/dolfinx/")
from dolfinx import fem, mesh, plot
from petsc4py import PETSc #solvers
from dolfinx.cpp.mesh import create_meshtags
from dolfinx.fem import (Constant, dirichletbc, Function, FunctionSpace,
                         form,  assemble_scalar, locate_dofs_geometrical, locate_dofs_topological, assemble, DirichletBC)
from dolfinx.mesh import create_unit_square, locate_entities, locate_entities_boundary
from ufl import (SpatialCoordinate, TestFunction, TrialFunction,
                 dx, grad, inner, Measure, dot, jump, FacetNormal, avg, FiniteElement, MixedElement)
from ufl import (FacetNormal, FiniteElement, Identity, Measure, TestFunction, TestFunctions, TrialFunction, VectorElement, MixedElement, as_vector, div, dot, ds, dx, inner, lhs, grad, nabla_grad, rhs, sym, curl, derivative, split)
## We define our problem specific parameters
dt = Constant(mesh, PETSc.ScalarType(1./1600))
nu = Constant(mesh, PETSc.ScalarType(1/500)) # nu = 1/Re
relax = Constant(mesh, PETSc.ScalarType(1e-6)) # relaxation constant
U_0 = 2 # longitunal/lenghtwise velocity at coordinate (x,y)=(0,H/2)
# Define constants
L = 1
a = 3.0
rho = 1.0
kappa= 0.25
# Define the parameters and functions involved in the equations
K_x, K_y = 1.0, 1.0  # Replace with actual values
K = [K_x, K_y]
a = 3
gamma = 0.7
delta = 0.0025
lambda_ = 0.5
T = 1.0
nu=0.25
num_steps = T / dt
# Boundary condtions ---------------------------------------------------------
u_plate = 25
u0 = 23
u0_1 = 21
u0_2 = 14
# Time  ----------------------------------------------------------------------
TotalTime = 1000.0
t0=time.time()
num_steps = 50     # number of time steps
dt = TotalTime / num_steps # time step size
t = 0 # current time
# Mesh
with XDMFFile(MPI.COMM_WORLD, "mesh.xdmf", "r") as xdmf:
    ct = xdmf.read_meshtags(mesh, name="Grid")
mesh.topology.create_connectivity(mesh.topology.dim, mesh.topology.dim - 1)
with XDMFFile(MPI.COMM_WORLD, "facet_mesh.xdmf", "r") as xdmf:
    ft = xdmf.read_meshtags(mesh, name="Grid")
ds = Measure('ds', domain=mesh, subdomain_data=ft)
# Define the variational problem
V = FunctionSpace(mesh, ("CG", 1))
Q = FunctionSpace(mesh, ("DG", 0))
u_elem = VectorElement('CG', mesh.ufl_cell(), 2) # displacement(2D)
v_elem= FiniteElement('CG', mesh.ufl_cell(), 1) # pore water pressure(scalar)
V    = FunctionSpace(mesh, MixedElement([u_elem, v_elem])) #Define vector function space for [u,p]
p = TrialFunction(Q)
q = TestFunction(Q)
f = Constant(mesh, PETSc.ScalarType(0))
#Trial function
xt = Function(V)
ut, vt = split(xt)
#Define function for step
x_n = Function(V)
print(x_n.vector.array)
u_n, v_n = split(x_n)
V0, submap = V.sub(0).collapse()
#Define boundary conditions and Neuman conditon in the above domain
# in the circle
Timp_facets = ft.find(FACE_MARK)
Timp_dofs = locate_dofs_topological(V, mesh.topology.dim-1, Timp_facets)
bc = dirichletbc(default_scalar_type(u_plate), Timp_dofs, V)
def boundary_D(x):
    return np.logical_or(np.isclose(x[0], 0), np.isclose(x[0], 1))
dofs_D = locate_dofs_geometrical(V, boundary_D)
u_bc = Function(V)
u_bc.interpolate(u_0)
bc = dirichletbc(u_bc, Timp_dofs)
Res = dot(u,v)*dx
Res += - dt*dot(K*grad(u), grad(v))*dx + dot(K*F1(u)*grad(u),v)*dx*dt
Res += - inner(p,q)*dx - a*inner(p, q)*dx*dt + gamma*inner((phiF(u, lambda_) - p), q)*dx*dt
Jac = derivative(Res, xt) # jacobian
Prob   = NonlinearProblem(Res, xt, bc, Jac)
solver = nls.petsc.NewtonSolver(MPI.COMM_WORLD, Prob)
# Set nonlinear solver parameters
solver.rtol = 1e-7 #relative_tolerance
solver.atol = 1e-7 #absolute_tolerance
solver.max_it = 100 #maximum_iterations
solver.report = True
# Solve system & output results
# time stepping
t_i = 0.0
t_f = 1.0
Nsteps = 100
time = np.linspace(t_i, t_f, Nsteps+1)
# output file
#xdmf = XDMFFile(domain.comm, "terzaghi.xdmf", "w")
#xdmf.write_mesh(domain)
with XDMFFile(MPI.COMM_WORLD, "ux.xdmf", "w") as xdmf1:
    xdmf1.write_mesh(mesh)
with XDMFFile(MPI.COMM_WORLD, "uy.xdmf", "w") as xdmf2:
    xdmf2.write_mesh(mesh)
with XDMFFile(MPI.COMM_WORLD, "v.xdmf", "w") as xdmf3:
    xdmf3.write_mesh(mesh)
t = 0
u, v = xt.split()
u.name = "u"
v.name = "v"
dx = u.sub(0).collapse()
dy = u.sub(1).collapse()
xdmf1.write_function(dx, t)
xdmf2.write_function(dy, t)
xdmf3.write_function(v, t)
for (i, dt) in enumerate(np.diff(time)):
    t = time[i+1]
    print('-----------------------------------------')
    print('>> t =', t, '[sec]')
    # solve system
    solver.solve(xt)
    x_n.vector.array[:] = xt.vector.array[:]
    # data for visualization
    u, v = xt.split()
    #xdmf_file.write(poro, t)
xdmf1.close()
xdmf2.close()
xdmf3.close()
I formatted your code with “```”, please do so next time, and also read Read before posting: How do I get my question answered?
Your code is super long and complex, yet you seem to have very basic questions (“how do I apply my BCs?”)
If I were you, I’d start from a much simpler case and learn the basics step by step. See The FEniCSx tutorial — FEniCSx tutorial for a possible tutorial.
There is a lot to unpack from your question. What you’ve posed is a research question where one must take great care, not only with boundary conditions, but with model formulation, discretisation, interpretation and so on. In this case it is both difficult and could be considered improper to provide off-the-cuff advice. I would recommend you discuss your problem with your academic supervisor or collaborator.
If, however, you are simply held back by the imposition of boundary conditions using dolfinx, I highly recommend the excellent tutorial written by @dokken.
