This might be a stupid question but i’ve been stuck what does this code mean on link Implementation — FEniCSx tutorial
i want to know what are the conditions of this problem actually. it seems like it doesn’t specify the top, bottom, left and right borders like other problems. if someone can explain in detail, i’ll be very greatful
Your mesh consists of facets that is classified as being on the boundary if:
A facet is only connected to a single cell.
For the example that we are considering, we are using a P1 finite element space where all degrees of freedom are located at vertices.
Every facet of a 2D (triangular or quadrilateral) mesh is a line segment consisting of two vertices.
Thus, for every facet located at the boundary, we find the corresponding vertices. For these vertices, we find the degrees of freedom associated with them, and apply the Dirichlet condition on these.
