Bug in extracting physical tags from sphere
I want to extract physical tags from my geometry all the way up to zero dimensional entities i.e. points using this script. However, I stumbled upon a strange bug in the process which appears to be present in gmshio.model_to_mesh too.
When it happens:
  1. The geometry is a sphere. Replacing it with a box removes the problem.
  2. Adding physical tags of dimension 1 (i.e. edges). Ordinarily, it should be ignored by gmshio.model_to_mesh
The following MWE produces it:
import gmsh, numpy as np, mpi4py
from dolfinx.io import gmshio
fov_R = 1
gmsh.finalize()
gmsh.option.setNumber("General.Terminal", 0) # disable output messages
gmsh.clear()
gdim = 3
occ = gmsh.model.occ
fov = occ.addSphere(0, 0, 0, fov_R) # does not work
# fov = occ.addBox(0, 0 ,0, fov_R, fov_R, fov_R) # works
occ.synchronize()
# number all domains
all_doms = gmsh.model.getEntities(gdim)
for j, dom in enumerate(all_doms):
    gmsh.model.addPhysicalGroup(dom[0], [dom[1]], j + 1)  # create the main group/node
# number all boundaries
all_edges = gmsh.model.getEntities(gdim - 1)
for j, edge in enumerate(all_edges):
    gmsh.model.addPhysicalGroup(edge[0], [edge[1]], edge[1])  # create the main group/node
# number all edges
all_edges = gmsh.model.getEntities(gdim - 2)
model_rank = 0
mesh, ct, ft = gmshio.model_to_mesh(gmsh.model, mpi4py.MPI.COMM_WORLD, model_rank, gdim)
Error message:
AssertionError                            Traceback (most recent call last)
Cell In[51], line 35
     32 gmsh.model.mesh.generate(gdim)
     34 model_rank = 0
---> 35 mesh, ct, ft = gmshio.model_to_mesh(gmsh.model, mpi4py.MPI.COMM_WORLD, model_rank, gdim)
File ~/miniconda3/envs/fenics-complex-0.9/lib/python3.13/site-packages/dolfinx/io/gmshio.py:245, in model_to_mesh(model, comm, rank, gdim, partitioner, dtype)
    243 # Get mesh geometry and mesh topology for each element
    244 x = extract_geometry(model)
--> 245 topologies = extract_topology_and_markers(model)
    247 # Extract Gmsh cell id, dimension of cell and number of nodes to
    248 # cell for each
    249 num_cell_types = len(topologies.keys())
File ~/miniconda3/envs/fenics-complex-0.9/lib/python3.13/site-packages/dolfinx/io/gmshio.py:139, in extract_topology_and_markers(model, name)
    133 for entity in entities:
    134     # Get cell type, list of cells with given tag and topology
    135     # of tagged cells NOTE: Assumes that each entity only have
    136     # one cell-type,
    137     # i.e. facets of prisms and pyramid meshes are not supported
    138     (entity_types, entity_tags, entity_topologies) = model.mesh.getElements(dim, tag=entity)
--> 139     assert len(entity_types) == 1
    141     # Determine number of local nodes per element to create the
    142     # topology of the elements
    143     properties = model.mesh.getElementProperties(entity_types[0])
AssertionError:
There was work on this in Extract edge tags and vertex tags from gmsh and return a NamedTuple by finsberg · Pull Request #3547 · FEniCS/dolfinx · GitHub and Refactor gmshio to use correct naming of subentities by jorgensd · Pull Request #3732 · FEniCS/dolfinx · GitHub
It will be in the next release, but you can easily get a preview of it right now.
A possible suggestion would be to
  1. make a backup of the gmshio.py file in your current installation, just in case you need to go back.
  2. download patches from https://github.com/FEniCS/dolfinx/pull/3732.patch and https://github.com/FEniCS/dolfinx/pull/3547.patch
  3. retain only the parts that change gmshio.py, i.e. ignore changes to demo
  4. apply the simplified patches, in order (3547 first, then the other)
  5. have a look at the changes to the demos in the PR to understand what you should change in your own script.
Thanks a lot Francesco for your quick reply and detailed instructions to fix it. I willy try and get back if there are issues.
Out of curiosity, is there an expected timeline for the new release?
Hopefully during the summer, but we can’t be more precise than that at the moment.
