Hello, I have a square plate which has 3 physical entities, namely boundary, inclusions, and domain. I wish to assign different material properties to the domain and inclusions. The inclusions are circular and randomly placed, so I am not aware of the coordinates. How do I do this in FEniCS using the data I already have from gmsh?
import dolfin
from dolfin import XDMFFile
import matplotlib
msh = meshio.read("/mnt/c/Users/ABC/sfepy/testrve.msh")
print(msh)
The output of the above print function is the no. of points, lines and cells, and finally the following
Cell sets: boundary, domain, inclusions, gmsh:bounding_entities
Point data: gmsh:dim_tags
Cell data: gmsh:physical, gmsh:geometrical
Field data: boundary, domain, inclusions
The further I have written the mesh into the xdmf files as
for cell in msh.cells:
if cell.type == "line":
tetra_cells = cell.data
elif cell.type == "triangle":
triangle_cells = cell.data
def create_mesh(mesh, cell_type, prune_z=True):
out_mesh = meshio.Mesh(points=mesh.points, cells={cell_type: cells}, cell_data={"name_to_read":[cell_data]})
if prune_z:
out_mesh.prune_z_0()
return out_mesh
line_mesh = create_mesh(msh, "line", prune_z=False)
meshio.write("mf.xdmf", line_mesh)
triangle_mesh = create_mesh(msh, "triangle", prune_z=False)
from mpi4py import MPI as mpi
from scipy.spatial.distance import cdist
mesh = Mesh()
infile.read(mesh)
mvc_2d = MeshValueCollection("size_t", mesh, 2)
infile.read(mvc_2d, "name_to_read")
mf_2d = cpp.mesh.MeshFunctionSizet(mesh, mvc_2d)
#boundary_markers = MeshFunction("size_t", mesh, mesh.topology().dim() - 1)
dx = Measure("dx", domain=mesh, subdomain_data=mf_2d)
This is what my mesh looks like
EDIT
I tried to implement what was given in the following link,
How to extract and use physical labels from GMSH surfaces on FEniCS (2D mesh)
mesh = Mesh()
infile.read(mesh)
domains = MeshFunction("size_t", mesh, mesh.topology().dim())
dx = Measure("dx",domain=mesh, subdomain_data=mf_2d)
dx1 = Measure("dx", domain=mesh, subdomain_data=mvc_2d, subdomain_id=1)
dx2 = Measure("dx", domain=mesh, subdomain_data=mvc_2d, subdomain_id=2)
print(assemble(Constant(1)*dx))
print(assemble(Constant(1)*dx(1)))
print(assemble(Constant(1)*dx(2)))
The result of which is
0.9999999999999996
0.0
0.0
