Calculate area of marked subdomain
Hey,
Is it possible to calculate the area of the cell faces that are marked in a subdomain?
Below is some test code using a basic hex mesh cube domain. I want to extend this to a complex tetrahedral mesh, so if possible I’d like to avoid iterating through the marked faces and calculating their areas manually.
from dolfin_adjoint import *
n = 10
Nx, Ny, Nz = n,n,n
mesh = BoxMesh.create(MPI.comm_world, [Point(0,0,0), Point(1,1,1)], [Nx, Ny, Nz],
                          CellType.Type.hexahedron)
DG_FS = FunctionSpace(mesh, "DG", 0)
CG_FS = FunctionSpace(mesh, "CG", 1)
CG_VFS = VectorFunctionSpace(mesh, "CG", 1)
class top(SubDomain):
        return on_boundary and near(x[1], 1.)
class bottom(SubDomain):
        return on_boundary and near(x[1], 0)
top = top()
bottom = bottom()
materials = MeshFunction('size_t', mesh, 2)
materials.set_all(0)
top.mark(materials, 1)
bottom.mark(materials, 2)
ds = Measure("ds")(subdomain_data=materials)
# Total area of top
top_area = .... # Exact value is 1 in this case
bottom_area = .... # Exact value is 1 in this case
Thanks,
Tom
The following resolves the issue:
ds = Measure("ds",domain=mesh, subdomain_data=materials)
# Total area of top
top_area = assemble(1*ds(1)) # Exact value is 1 in this case
bottom_area =assemble(1*ds(2)) # Exact value is 1 in this case
print(top_area, bottom_area)
Please note that support for hexahedral meshes is very limited in dolfin, and has been improved and extended in dolfinx
Thanks for your quick response!
However, I’m getting a UFL error in assemble(1*ds(1)):
UFLException: This integral is missing an integration domain.
Do you know how I can fix this? Apologies if this is a trivial question, I’m quite new to FEniCS.
You need to define ds as I did,
Setting domain=mesh removes your error
Ah I didn’t notice that - work’s now! Thank you.
Is it possible to solve this problem in dolfinx? It seems, this solution doesn’t work for dolfinx
Could you elaborate, what exactly does not work for you? Could you provide a minimal example?
Sorry. For dolfinx I did the following
   one = Constant(mesh, ScalarType(1.))
   f = form(one*ds(2))
   area = assemble_scalar(f)
It works.
