I have a complex geometry. This geometry has not regular shape, so I can not access to different boundaries and domains with specifying the coordinate.
I mesh this geometry in GMSH with defining domains and boundaries. I have two PDEs to solve, PDE1 for domain 1, and PDE2 for domain2. My problem is I can not define the integrand for each subdomain. With this code, I got the following results:
The area of subdomain 1 is 0.000000e+00
which means, the subdomain is not defined.
msh = meshio.read("convertMesh/mchip_2D.msh")
cells = numpy.vstack([cell.data for cell in mesh.cells if cell.type==cell_type])
cell_data = numpy.hstack([mesh.cell_data_dict["gmsh:physical"][key]
for key in mesh.cell_data_dict["gmsh:physical"].keys() if key==cell_type])
# Remove z-coordinates from mesh if we have a 2D cell and all points have the same third coordinate
points= mesh.points
if prune_z:
points = points[:,:2]
mesh_new = meshio.Mesh(points=points, cells={cell_type: cells}, cell_data={"name_to_read":[cell_data]})
return mesh_new
line_mesh = create_mesh(mesh_from_file, "line", prune_z=True)
triangle_mesh = create_mesh(mesh_from_file, "triangle", prune_z=True)
meshio.write("convertMesh/mchip_2D_boundary.xdmf", line_mesh)
meshio.write("convertMesh/mchip_2D_surface.xdmf", triangle_mesh)
mesh = Mesh()
with XDMFFile("convertMesh/mchip_2D_surface.xdmf") as infile:
infile.read(mesh)
mvc_1d = MeshValueCollection("size_t", mesh, 1)
with XDMFFile("convertMesh/mchip_2D_boundary.xdmf") as infile:
infile.read(mvc_1d, "name_to_read")
mf_1d = cpp.mesh.MeshFunctionSizet(mesh, mvc_1d)
mvc_2d = MeshValueCollection("size_t", mesh, 2)
infile.read(mvc_2d, "name_to_read")
mf_2d = cpp.mesh.MeshFunctionSizet(mesh, mvc_2d)
class Porous(SubDomain):
return mf_2d == 70
class Fluid(SubDomain):
return mf_2d == 71
domains = MeshFunction("size_t", mesh, mesh.topology().dim(), mesh.domains())
domains.set_all(10)
porous = Porous()
porous.mark(domains, 1)
fluid = Fluid()
fluid.mark(domains, 2)
mf = MeshFunction('size_t',mesh,2, domains)
dx = Measure('dx', domain=mesh, subdomain_data=domains)
s1 = assemble(Constant(1)*dx(1))
print("The area of subdomain 1 is {:2e}".format(s1))
