This is my full code, it is just the classic plate with a hole and traction, using quarter symmetry and plane stress. The for loop is just to vary the grid size.
from ufl import nabla_div
return sym(grad(u))
def sigma(u):
return lamtr(epsilon(u)) * Identity(2) + 2.0mu*epsilon(u)
def left(x): return x[0] < DOLFIN_EPS
def bottom(x): return x[1] < DOLFIN_EPS
def right(self,x,on_boundary): return x[0] > 2-DOLFIN_EPS
class Trac(SubDomain):
return near(x[0], 2.0)
p=0.1
E=2.2
nu=1.0/10.0
mu=E/(2*(1+nu))
lam = Enu/((1+nu)(1-2nu)) ## plane strain
lam = 2mulam/(lam+2mu)
geo = Rectangle(dolfin.Point(0., 0.), dolfin.Point(2., 1.))
- Circle(dolfin.Point(0.0, 0.0), 4.0/7.0)
for grid in range(2,50):
mesh=generate_mesh(geo, grid )
zero = Constant(0.0)
bc1 = DirichletBC(V.sub(0), zero, left)
bc2 = DirichletBC(V.sub(1), zero, bottom)
bc = [bc1, bc2]
du = TrialFunction(V)
a = inner(sigma(du), epsilon(v))*dx
boundary_subdomains = MeshFunction("size_t", mesh, mesh.topology().dim() - 1)
boundary_subdomains.set_all(3)
trac=Trac()
trac.mark(boundary_subdomains, 1)
dss=Measure('ds', domain=mesh, subdomain_data=boundary_subdomains)
T = Constant( (p, 0) ) # surface traction
L = inner(T, v)*dss(1)
# Compute solution
solve(a == L, u, bc)
a = inner(sigma(u), epsilon(u))*dx
L = inner(T, u)*dss(1)
pi = assemble(a-L)
print(pi)
