Hi again,
I am trying to verify that my method behaves as intended. I want to solve equations on the sphere, and below is my attempt to verify the method through solving the Laplace-Beltrami equation, with the 2,2-real spherical harmonic times its eigenvalue as right-hand side, which is an eigenfunction, so I know the result. Theoretically I know that the error of the method should behave as h^2, where h is the max size of the triangle. However, what comes out behaves strangley. I think what I do can be relatated to how I calculate the error. See below, errornorm gives warning and should according to old discussions, ~2016 not be used. Instead I try to compile the error, but it does not work at all. I ideally want to integrate over “sphere”, but that does not seem to work. I think I have to compare them on the same mesh, so I choose the finest, like I do below, but it does not work. Any suggestions? And when should I use ds and not dx in fenics? Best regards!
#Domain
N=[8,16,32,64]
n=len(N)
print(n)
errors=np.zeros([n,1])
sizes=np.zeros([n,1])
sphere=Sphere(Point(0,0,0),1)
global_normal=Expression(('x[0]','x[1]','x[2]'),degree=2)
surfaces=[BoundaryMesh(generate_mesh(sphere,i),"exterior") for i in N]
ref_surface=surfaces[-1]ref_surface=surfaces[-1]
f = Expression("6*sqrt(15)*(x[0]*x[0]-x[1]*x[1])/(16*sqrt(pi))",degree=2) #error
Y22=Expression("sqrt(15)*(x[0]*x[0]-x[1]*x[1])/(16*sqrt(pi))",degree=2)
file=File("./testim/ver.pvd")
def verificator(N,surface):
surface.init_cell_orientations(global_normal)
P1 = FiniteElement("P", surface.ufl_cell(), 1)
C=FiniteElement("R",surface.ufl_cell(),0)
V = FunctionSpace(surface,P1*C)
(u,c) = TrialFunction(V)
(v,d) = TestFunction(V)
a = inner(grad(u), grad(v))*dx+(c*v+u*d)*dx
L = f*v*dx
# Compute solution
w = Function(V)
solve(a == L, w)
(x,y)=w.split()
eig=6 #l*(l+1)
file<<x
size=surface.hmax() #have to do for now
# return([errornorm(Y22,x,'L2',5,mesh=surface),size]) #yields a strange error
return([assemble((Y22-x)**2*dx(ref_surface)),size])
for i in range(n):
v=verificator(N[i],surfaces[i])
errors[i]=v[0]
sizes[i]=v[1]
np.savetxt('ver.txt',(np.log(errors),np.log(sizes)))
plt.plot(np.log(sizes),np.log(errors))
plt.savefig("ver.png")
