How do I calculate error on each node?
I run the heat equation code. I am wondering, how to calculate the error on each node, and how to save the solution in xdml format?
T = 2.0            # final time
num_steps = 10     # number of time steps
alpha = 3          # parameter alpha
beta = 1.2         # parameter beta
nx = ny = 8
mesh = UnitSquareMesh(nx, ny)
dof_coordinates = V.tabulate_dof_coordinates()
# Define boundary condition
u_D = Expression('1 + x[0]*x[0] + alpha*x[1]*x[1] + beta*t',
                 degree=2, alpha=alpha, beta=beta, t=0)
def boundary(x, on_boundary):
    return on_boundary
# Define initial value
u_n = interpolate(u_D, V)
#u_n = project(u_D, V)
f = Constant(beta - 2 - 2*alpha)
F = u*v*dx + dt*dot(grad(u), grad(v))*dx - (u_n + dt*f)*v*dx
a, L = lhs(F), rhs(F)
# Time-stepping
t = 0
for n in range(num_steps):
    # Update current time
    u_D.t = t
    # Compute solution
    solve(a == L, u, bc)
    #print(dof_coordinates)
    print(dof_coordinates, u.vector().get_local())
    # Plot solution
    plot(u)
    plot(mesh, title="Solution to Heat Equation")
    # Compute error at vertices
    u_e = interpolate(u_D, V)
    error = np.abs(u_e.vector().get_local() - u.vector().get_local()).max()
    print('t = %.2f: error = %.3g' % (t, error))
    #plot(t,error)
    # Update previous solution
    u_n.assign(u)
# Hold plot
Please see the attached tutorial:
https://fenicsproject.org/pub/tutorial/html/._ftut1004.html#___sec35
For writing xdmf files, see for instance: Loading xdmf data back in - #4 by dokken
