Can Fenics handle Dirichlet boundary conditions on DG spaces?
I want to solve the Poisson equation by defining its fields on DG spaces. The boundary value problem is
\nabla^2 u = f \, \text{in }\Omega
u = u_0 \text{ on } \partial\Omega
where \Omega is a disk.
I managed to solve this by imposing the boundary condition (BC) with a penalty term, but I would like to enforce it strongly as a DirichletBC, for reasons related to future developments.
Is this possible?
Here is the minimal working example where the BC is imposed with penalty (yes, I am purposedly using a nonlinear solver for future developments):
# ── Mesh ─────────────────────────────────────────────────────────────────────
r = 1.0          # disk radius
N = 32           # mesh resolution (number of cells along diameter)
mesh = UnitDiscMesh.create(MPI.comm_world, N, 1, 2)
# ── Parameters ───────────────────────────────────────────────────────────────
degree = 2       # polynomial degree of DG space
alpha  = 10.0    # penalty parameter (must be large enough)
h      = CellDiameter(mesh)
n      = FacetNormal(mesh)
# ── Function space ────────────────────────────────────────────────────────────
Q      = FunctionSpace(mesh, 'DG', degree)
u      = Function(Q)
nu     = TestFunction(Q)
J_u    = TrialFunction(Q)
# ── Exact solution and RHS ───────────────────────────────────────────────────
class u_exact_expression(UserExpression):
    def eval(self, values, x):
        values[0] = 1 + x[0]**2 + 2*x[1]**2
    def value_shape(self):
        return (1,)
class f_expression(UserExpression):
        values[0] = 6
        return (1,)
u_exact = Function(Q)
f       = Function(Q)
u_exact.interpolate(u_exact_expression(element=Q.ufl_element()))
f.interpolate(f_expression(element=Q.ufl_element()))
i = ufl.indices(1)[0]
# ── Variational form ─────────────────────────────────────────────────────────
def jump(v, nn): return v('+') * nn('+') + v('-') * nn('-')
def avg(v):      return 0.5 * (v('+') + v('-'))
# F_0: bulk term + natural Neumann term
F_0 = (u.dx(i)*nu.dx(i) + f*nu) * dx \
    - n[i] * u.dx(i) * nu * ds
# F_I: interior penalty
F_I = (
    - avg(u.dx(i)) * jump(nu, n)[i]
    + alpha/h('+') * jump(u, n)[i] * jump(nu, n)[i]
) * dS
F_E = (
    alpha/h * (u - u_exact) * nu
) * ds
F = F_0 + F_I + F_E
solve(F == 0, u, [])
error_L2 = errornorm(u_exact, u, 'L2')
print(f"L2 error = {error_L2:.3e}")
and here the one where I try to impose it with DirichletBC
r = 1.0
N = 32
degree = 2
u      = Function(Q)
        return (1,)
        values[0] = 6
        return (1,)
f       = Function(Q)
alpha = 10.0
# ── Strong Dirichlet BC ───────────────────────────────────────────────────────
class Boundary(SubDomain):
        return on_boundary
bc = DirichletBC(Q, u_exact, Boundary())
print(f"Constrained DOFs = {len(bc.get_boundary_values())}")
F_I = (
) * dS
F = F_0 + F_I
solve(F == 0, u, [bc])
The first one works, it gives:
# python3 mwe_penalty.py
No Jacobian form specified for nonlinear variational problem.
Differentiating residual form F to obtain Jacobian J = F'.
  Newton iteration 0: r (abs) = 2.048e+02 (tol = 1.000e-10) r (rel) = 1.000e+00 (tol = 1.000e-09)
  Newton iteration 1: r (abs) = 1.054e-12 (tol = 1.000e-10) r (rel) = 5.146e-15 (tol = 1.000e-09)
  Newton solver finished in 1 iterations and 1 linear solver iterations.
*** Warning: Degree of exact solution may be inadequate for accurate result in errornorm.
L2 error = 1.395e-12
The second one fails (0 constrained DOFs), it gives:
# python3 mwe_dirichlet.py
Constrained DOFs = 0
  Newton iteration 0: r (abs) = 1.388e-01 (tol = 1.000e-10) r (rel) = 1.000e+00 (tol = 1.000e-09)
  Newton iteration 1: r (abs) = 1.119e-12 (tol = 1.000e-10) r (rel) = 8.058e-12 (tol = 1.000e-09)
L2 error = 4.462e+00
How can I make the Dirichlet code work by keeping DG spaces?
Thank you
In principle, the DG formulation is not “designed” for strong imposition of Dirichlet data. The huge advantage of the DG method is the rich selection of employable basis functions. E.g., one could choose from nodal, or modal bases. Furthermore, the weak imposition of Dirichlet data yields a global approximate solution closer to the true solution than by strongly imposing an interpolation or trace projection of your Dirichlet data.
All that said, if you really want to strongly impose Dirichlet data for a DG scheme, this could be achieved with a nodal basis and a spatial lookup for the degrees of freedom located on the exterior facets on which you wish to impose that data.
I’m not sure what basis is used by legacy FEniCS in the default case for “'DG'” in a function space. I think it may be a nodal basis of interpolatory Lagrange polynomials defined in each cell. So if you use the geometric or pointwise search to find those degrees of freedom aligned with the facets on which you want to impose Dirichlet boundary conditions, it should work. You can find the documentation here: Bitbucket
Thank your for your reply, this was very useful!
