I try to simplify my problem in the following example. Here I solve the heat equation with two different materials with a discontinuous method using the following domain:
Here is the code:
from dolfinx import fem, mesh, io, plot
from ufl import dot, grad, jump, avg, FacetNormal, Circumradius, dx, ds, dS
# Define temporal parameters
t = 0 # Start time
T = 2.0 # Final time
num_steps = 61
# Define mesh
nx, ny = 50, 50
domain = mesh.create_rectangle(MPI.COMM_WORLD, [np.array([-2, -2]), np.array([2, 2])], [nx, ny], mesh.CellType.triangle)
V = fem.FunctionSpace(domain, ("DG", 1))
Q = fem.FunctionSpace(domain, ("DG", 0))
def Omega_1(x):
return x[1] >= 0.0
def Omega_2(x):
return x[1] <= 0.0
kappa = fem.Function(Q)
cells_1 = mesh.locate_entities(domain, domain.topology.dim, Omega_1)
cells_2 = mesh.locate_entities(domain, domain.topology.dim, Omega_2)
kappa.x.array[cells_1] = np.full_like(cells_1, 1, dtype=ScalarType)
kappa.x.array[cells_2] = np.full_like(cells_2, 0.01, dtype=ScalarType)
# Create initial condition
def initial_condition(x, a=5):
return np.exp(-a*(x[0]**2+x[1]**2))
u_n = fem.Function(V)
u_n.name = "u_n"
u_n.interpolate(initial_condition)
xdmf = io.XDMFFile(domain.comm, "output.xdmf", "w")
xdmf.write_mesh(domain)
# Define solution variable, and interpolate initial solution for visualization in Paraview
uh = fem.Function(V)
uh.name = "uh"
uh.interpolate(initial_condition)
xdmf.write_function(uh, t)
f = fem.Constant(domain, PETSc.ScalarType(0))
uD = fem.Constant(domain, PETSc.ScalarType(0))
n = FacetNormal(domain)
# bilinear form
a = u * v * dx + dt * dot(grad(u), grad(kappa * v)) * dx
a += dt * (dot(jump(u, n), avg(grad(kappa * v))) - dot(avg(grad(kappa * u)), jump(v, n))) * dS
a += dt * (dot(u * n, grad(kappa * v)) - dot(grad(kappa * u), v * n)) * ds
a += dt * dot(jump(u, n), jump(v, n)) * dS
a += dt * dot(u * n, v * n) * ds
# liniear form
L = (u_n + dt * f) * v * dx
L += dt * dot(uD * n, grad(kappa * v)) * ds
L += dt * uD * v * ds
bilinear_form = fem.form(a)
linear_form = fem.form(L)
A = fem.petsc.assemble_matrix(bilinear_form)
b = fem.petsc.create_vector(linear_form)
solver.setOperators(A)
for i in range(num_steps):
with b.localForm() as loc_b:
loc_b.set(0)
fem.petsc.assemble_vector(b, linear_form)
# Solve linear problem
solver.solve(b, uh.vector)
uh.x.scatter_forward()
u_n.x.array[:] = uh.x.array
# Write solution to file
xdmf.close()
I use a weak imposition of the Dirichlet boundary which is zero on the external boundary of the domain. What I need to know is how to modify / add a term to my variational formulation to impose a boundary condition on interior nodes, in this case subdomain 2 to fixate the solution there.
For the variational formulation I use an interior penalty method with all parameters set to 1 for simplicity.
