I am trying to save a time-dependent equation into a single file and then to visualize externally. The code (not all) is below
u,v = ufl.TestFunction(V), ufl.TrialFunction(V)
Now, we interpolate the function f over the mesh
Q = fem.functionspace(msh, (“Lagrange”, 5))
expr = fem.Expression(source, V.element.interpolation_points())
f = fem.Function(V)
f.interpolate(expr)
un = fem.Function(V)
un.x.array[:] = f.x.array
a = (uv + ufl.dot(ufl.grad(u), ufl.grad(v))) * ufl.dx
L =((un + dtf) * v ) * ufl.dx
uh = fem.Function(V)
uh.x.array[:] = un.x.array
xdmf = io.XDMFFile(msh.comm, “HeatEquation.xdmf”, “w”)
xdmf.write_mesh(msh)
bilinear_form = fem.form(a)
linear_form = fem.form(L)
A = assemble_matrix(bilinear_form, bcs= [bc])
b = create_vector(linear_form)
solver = PETSc.KSP().create(msh.comm)
solver.setOperators(A)
for i in range(num_steps):
with b.localForm() as loc_b:
loc_b.set(0)
assemble_vector(b, linear_form)
apply_lifting(b, [bilinear_form], [[bc]])
set_bc(b, [bc])
# Solve linear problem
solver.solve(b, uh.x.petsc_vec)
uh.x.scatter_forward()
un.x.array[:] = uh.x.array
# Write solution to file
xdmf.write_function(uh, t)
xdmf.close()
But when I visualize uh using pyvista, I have something like this
P.S. Is there another way to save file to be compatible with VisIT? Or do you know some other software for post-processing. I tried with OVITO, but it says it cannot open the file, even if I tried to save them as .pvt or .vtk
I use JupyterLab in Doker
