Heat equation with explicit euler
Hello everyone,
I wanted to use an explicit Euler as time discretization for the heat equation from the tutorial. When i run the code every second time step is zero, when i review the xdmf.file. Has anyone an idea how to fix this?
from dolfinx import fem, mesh, io, plot
# Define temporal parameters
t = 0 # Start time
T = 1.0 # Final time
num_steps = 100
# Define mesh
nx, ny = 5, 5
domain = mesh.create_rectangle(MPI.COMM_WORLD, [np.array([-2, -2]), np.array([2, 2])],
                               [nx, ny], mesh.CellType.triangle)
# Create initial condition
def initial_condition(x, a=5):
    return np.exp(-a*(x[0]**2+x[1]**2))
u_n = fem.Function(V)
u_n.name = "u_n"
u_n.interpolate(initial_condition)
# Create boundary condition
boundary_facets = mesh.locate_entities_boundary(
    domain, fdim, lambda x: np.full(x.shape[1], True, dtype=bool))
bc = fem.dirichletbc(PETSc.ScalarType(0), fem.locate_dofs_topological(V, fdim, boundary_facets), V)
xdmf = io.XDMFFile(domain.comm, "explicit.xdmf", "w")
xdmf.write_mesh(domain)
# Define solution variable, and interpolate initial solution for visualization in Paraview
uh = fem.Function(V)
uh.name = "uh"
uh.interpolate(initial_condition)
xdmf.write_function(uh, t)
f = fem.Constant(domain, PETSc.ScalarType(0))
a = u * v * ufl.dx
L = (dt*ufl.dot(ufl.grad(u_n), ufl.grad(v))-u_n*v-dt*f*v)*ufl.dx
bilinear_form = fem.form(a)
linear_form = fem.form(L)
A = fem.petsc.assemble_matrix(bilinear_form, bcs=[bc])
b = fem.petsc.create_vector(linear_form)
solver.setOperators(A)
for i in range(num_steps):
    with b.localForm() as loc_b:
        loc_b.set(0)
    fem.petsc.assemble_vector(b, linear_form)
    fem.petsc.apply_lifting(b, [bilinear_form], [[bc]])
    fem.petsc.set_bc(b, [bc])
    # Solve linear problem
    solver.solve(b, uh.vector)
    u_n.x.array[:] = uh.x.array
    # Write solution to file
xdmf.close()
There is a mistake here, this should be
L = (-dt*ufl.dot(ufl.grad(u_n), ufl.grad(v))+u_n*v-dt*f*v)*ufl.dx
You need to make the signs consistent with a=L, not F=0
Hello Fenics users,
I want to solve the problem using a nonlinear solver to solve F = 0.
But I do not know which couple lines of code I should use to save my solution in xdmf file and then visualise it with paraview.
Here is my code:
#https://fenicsproject.discourse.group/t/heat-equation-with-explicit-euler/10987
from dolfinx.io import XDMFFile, VTXWriter
from dolfinx.fem.petsc import assemble_vector, assemble_matrix, create_vector, apply_lifting, set_bc
from dolfinx.mesh import CellType, create_rectangle, locate_entities_boundary
from dolfinx.fem import (Constant, dirichletbc, Function, FunctionSpace, assemble_scalar,
                         form, locate_dofs_geometrical, locate_dofs_topological, set_bc)
from ufl import dx, grad, inner, TrialFunction, derivative, dot
from dolfinx.fem.petsc import NonlinearProblem, LinearProblem
t = 0 # Start time
num_steps = 100
# Define mesh
nx, ny = 16, 16
domain = mesh.create_rectangle(MPI.COMM_WORLD, [np.array([0, 0]), np.array([1, 1])],
V = fem.FunctionSpace(domain, ("Lagrange", 1))
# Interpolate initial condition
#def initial_condition(x, a=0):
#    return np.exp(-a*(x[0]**2+x[1]**2))
u_n.name = "u_n"
#u_n.interpolate(initial_condition)
u_n.interpolate(lambda x: np.full(x.shape[1], PETSc.ScalarType(0.), dtype=np.float64))
#We create two python functions for determining the facets to apply boundary conditions to
def right(x):
    return np.isclose(x[0], 1)  #right (x = 1)
def top(x):
    return np.isclose(x[1], 1)  #top (y = 1)
######## Dirichlet boundary conditions #############
boundary_facets_right = locate_entities_boundary(domain, domain.topology.dim - 1, right)
boundary_dofs_right = locate_dofs_topological(V, domain.topology.dim - 1, boundary_facets_right)
bc_m_right = dirichletbc(PETSc.ScalarType(1.), boundary_dofs_right, V)
boundary_facets_top = locate_entities_boundary(domain, domain.topology.dim - 1, top)
boundary_dofs_top = locate_dofs_topological(V, domain.topology.dim - 1, boundary_facets_top)
bc_m_top = dirichletbc(PETSc.ScalarType(1.), boundary_dofs_top, V)
bcs = [bc_m_right, bc_m_top]  #dirichlet boundary conditions
#xdmf = io.XDMFFile(domain.comm, "explicit_30th_june_2024.xdmf", "w")
#xdmf.write_mesh(domain)
file = XDMFFile(domain.comm, "implicit_30th_june_2024_Nonlinear_solver.xdmf", "w")
file.write_mesh(domain)
uh.name = "uh"
#uh.interpolate(initial_condition)
uh.interpolate(lambda x: np.full(x.shape[1], PETSc.ScalarType(0.), dtype=np.float64))
file.write_function(uh, t)
u, v = fem.Function(V), ufl.TestFunction(V)
a = (u * v + dt*ufl.dot(ufl.grad(u), ufl.grad(v))) * ufl.dx
L = (u_n*v + dt*f*v)*ufl.dx
F = a - L
# Non linear problem definition
du  = TrialFunction(V)
#Compute the jacobian
Jac = derivative(F, u, du)
problem = NonlinearProblem(F, u, bcs = bcs, J = Jac)
solver.convergence_criterion = "incremental"      #residual    #incremental
# Absolute tolerance
solver.atol = 5e-10
solver.rtol = 1e-12 #0.0 #1e-14 #0.0 #1e-12
#solver.max_it = 70
solver.report = True
#solver.max_it = 100        #To increase the number of iterations
solver.error_on_nonconvergence = False
solver.max_it = 3
info = solver.solve(u)
print(info)
Thank you.
Please look at the tutorial
https://jsdokken.com/dolfinx-tutorial/chapter2/diffusion_code.html#time-dependent-output
Thank you @dokken. This is my benchmark tutorial. It uses linear solver to solve a=L. But I am struggling to modify
in my own that’s why I use nonlinear solver to solve F=0.
But I do not know how to save and visualise my results with Paraview.
This is my attempt:
    #with b.localForm() as loc_b:
        #loc_b.set(0)
    #fem.petsc.assemble_vector(b, linear_form)
    #fem.petsc.apply_lifting(b, [bilinear_form], [[bc]])
    #b.ghostUpdate(addv=PETSc.InsertMode.ADD_VALUES, mode=PETSc.ScatterMode.REVERSE)
    #fem.petsc.set_bc(b, [bc])
    # Solve nonlinear problem
    #solver.solve(b, uh.vector)
    solver.solve(u)
    u_n.x.scatter_forward()
But the solution is the same at every second time step.
    #loc_b.set(0)
solver.solve(u)
#u = uh
file.close()
So your issue is not storing the solution, But updating the solution over time?
As you haven’t provided a code that reproduces the behavior it is hard to give any specific pointers.
Yes @dokken , this is my issue.
Here is my code for approximating the 2D heat equation using FEM. The initial condition u(t=0, x, y) = 0 and boundaries conditions (top and right) are equal to 1.
Here is my code :
t = 0 # Start time
num_steps = 100
# Define mesh
nx, ny = 16, 16
u_n.name = "u_n"
def right(x):
def top(x):
uh.name = "uh"
F = a - L
#Solve variational problem
# Create nonlinear problem and Newton solver
solver.atol = 5e-10
solver.max_it = 3
print(info)
But in this code you have not attempted to write the solution to file. Could you please provide a reproducible example were you store multiple time steps.
In the code above you only call:
once, for t=0
Yes, here is:
        #loc_b.set(0)
    solver.solve(u)
    #u = uh
file.close()
